Lib Calc
Re: Lib Calc
Thanks calculator makers :)
Every business application need a calculator within in.
Regards, Saludos
Vanguarda
Re: Lib Calc
Post by Vanguarda »
mol wrote:by HMG dreams become reality :D
i agree with you.
regards,
Re: Lib Calc
Hola amigos
Les dejo la Calculadora que publicó el amigo Vanguarda, con algunos pequeños
arreglos efectuados en las teclas.
El proposito general de este sample ha sido reconvertir a UTF-8 con el programa
iniciado por Esgici y continuado por Serge.
Veran los dos ficheros ,original ANSI_Calculator.prg y reconvertido a UTF-8
Calculator.prg con los cambios efectuados por el nuevo programa de Serge
CFANS2UT8.exe viewtopic.php?f=10&t=3416&start=10" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
cambios en el fichero: CAF2UT8.HTM
Un saludo
Mustafa :P
Hello friends
I leave Calculator friend who published Vanguarda, with some small
arrangements made on the keys.
The general purpose of this sample has been convert to UTF-8 with the program
Esgici initiated and continued by Serge.
Veran the two files, original ANSI_Calculator.prg and converted to UTF-8
Calculator.prg with the changes made by the new program Serge
changes in the file: CAF2UT8.HTM
Mustafa :P
Calculator.zip
(14.94 KiB) Downloaded 527 times
Re: Lib Calc
Gracias / Thanks Vanguarda, Mustafa, Esgici and Serge por compartir / for sharing
Re: Lib Calc
Gracias a todos por compartir.
Re: Lib Calc
danielmaximiliano wrote:Gracias / Thanks Vanguarda, Mustafa, Esgici and Serge por compartir / for sharing
Re: Lib Calc
Mustafa,
Very nice! And also nice to see that CAF2UT8 did a nice job!
Agil Abdullah
Re: Lib Calc
Post by Agil Abdullah »
Hi Vangurda and Friends,
Many thanks for your sharing. That's I am looking for these days.
Thanks also to Mr.Esgici who showed me this thread this evening.
Salam Hangat from Jakarta
Programmer Never Surrender
SALINETAS24
Re: Lib Calc
Post by SALINETAS24 »
Hola, he incorporado la calculadora a un pequeño programa que estoy haciendo. Desde el Menú la puedo activar, bien con una opción del mismo menú o bien pulsado la tecla de función F3.
Pero cuando desde el Menu voy a otra opción articulos, clientes, etc., la calculadora se me desactiva.
Hay alguna forma de que se active la calculadora pulsado F3 desde cualquier parte del programa o cualquier modulo.
Gracias.
Y muy chula
Re: Lib Calc
SALINETAS24 wrote: Thu Apr 19, 2018 9:36 pm Hola, he incorporado la calculadora a un pequeño programa que estoy haciendo. Desde el Menú la puedo activar, bien con una opción del mismo menú o bien pulsado la tecla de función F3.
Gracias.
Y muy chula
For example:
Function Main ()
CREATE EVENT PROCNAME MyFuncKey ()
Function MyFuncKey ()
IF HMG_GetLastVirtualKeyDown () == VK_F3
HMG_CleanLastVirtualKeyDown()
Calc.Setfocus
Return nil
