Edit_TxT_PdF
Re: Edit_TxT_PdF
esgici wrote:
mustafa wrote: I changed "Save a txt" is not taken TXT extension to write it only put the name of the file, the bad news is that if you keep on top of an existing file.txt is created with the same double extension such document.txt.txt
Hola Mustafa
Please try to adding
  IF  "." $ Cfile
    CfileD := Cfile
    CfileD := Cfile+".txt"
to Procedure TextoGraba between
cContenido := Frm_1.Edit_1.value
and
SetCurrentFolder( cPrgFolder )
Hello Esgici
I think it must run well
Cfile:=putfile({{'txt','*.txt'},{'Configuracion','*.ini'}},"Grab\arArchivo")
IF "." $ Cfile
CfileD := Cfile
IF MEMOWRIT(CFileD,cContenido,.T.)
msginfo("No se pudo grabar el archivo ","ATENCION !!!")
Frm_1.Edit_1.value:=" "
SAVE TO memuar ALL LIKE cFileD*
Convierte()
testing your code does not touch but showed an error and SDF
was created with a single empty file extension. TXT nameless,
I do not see this error again
Date:22/05/2009 Time: 18:10:37
Error SDF/1001 Open error: .txt.txt (DOS Error 2)
Called from __DBAPP(0)
Called from __DBSDF(0)
Called from CONVIERTE(266)
Called from TEXTOGRABA(246)
Called from (b)MAIN(115)
Called from _DOCONTROLEVENTPROCEDURE(4394)
Called from EVENTS(1274)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4083)
Called from MAIN(158)
thanks for everything
Re: Edit_TxT_PdF
mustafa wrote:
Hola Mustafa
  IF  "." $ Cfile
    CfileD := Cfile
and
Hello Esgici
IF "." $ Cfile
CfileD := Cfile
Convierte()
Hola Esgici
creo que ya se lo que pasa con el error
si cargas un fichero para retocarlo y luego quieres guardarlo con su nombre u otro nombre pero cancelas la accion es cuando sale el error que te adjunto
Hello Esgici
I think it is what happens to the error
If you load a file you want to play and then save it with your name or other name but the action is canceled when you get the error attached
Mustafa greetings
Re: Edit_TxT_PdF
Hola Mustafa
Please try following :
  IF !EMPTY( Cfile )
     IF  "." $ Cfile
       CfileD := Cfile
     Convierte()
  ENDIF !EMPTY( Cfile )
Re: Edit_TxT_PdF
esgici wrote:Hola Mustafa
  IF !EMPTY( Cfile )
     IF  "." $ Cfile
       CfileD := Cfile
     Convierte()
Hello Esgici
As always you have gone faster with the solution, ja .... ja ....
I found another solucioón you can serve.
IF "." $ Cfile
CfileD := Cfile
RESTORE FROM MEMUAR ADDITIVE
IF cFile <= space(1)+".txt"
msginfo("Acción Cancelada","ATENCION !!!")
SAVE TO memuar ALL LIKE SPACE(1)
ERASE .txt
Convierte()
Many greetings
Re: Edit_TxT_PdF
Hola a todos les mando una prolongacion para convertir tambien a Doc
Hello command them to become an extension to Doc
Greetings
EditTxTPdFDoC.zip
(153.96 KiB) Downloaded 579 times
