Page 2 of 6
Re: ComboSearchGrid
Posted: Thu Apr 25, 2013 8:15 pm
It is and will be working for 3.0.46 but not in 3.1.2 because, we have to accommodate all string functions to unicode first. Till such time it is for 3.0.46 only. Soon I will make for 3.1.2 too.
Re: ComboSearchGrid
Posted: Mon Nov 25, 2013 3:28 pm
by tonton2
good evening
May I know where to find the options "ComboSearchGrid"
thank you in advance
Re: ComboSearchGrid
Posted: Mon Nov 25, 2013 3:42 pm
Meaning the source code?
Re: ComboSearchGrid
Posted: Wed Sep 24, 2014 12:50 pm
by zorpavns
Why ComboSearchGrid not compile in HMG 3.3.1
Re: ComboSearchGrid
Posted: Wed Sep 24, 2014 1:25 pm
by bpd2000
zorpavns wrote:Why ComboSearchGrid not compile in HMG 3.3.1
Modify hmg.hbc line no. 34 from
# libs=sqlite3
to
libs=sqlite3
Now compile ComboSearchGrid
or
Add libs=sqlite3 in csg.hbc and use command line as
c:\hmg\build csg csg.hbc
Re: ComboSearchGrid
Posted: Wed Sep 24, 2014 2:11 pm
by Agil Abdullah
# libs=sqlite3
to
libs=sqlite3
or
Yes... I just tried and worked very well.... Thanks to everybody in this thread.
Re: ComboSearchGrid
Posted: Wed Sep 24, 2014 4:19 pm
by Javier Tovar
Hola Sr. Rathinagiri,
Al querer compilar si ejemplo en HMG3.3.1 me da el siguiente error:
- ErrorSqlite3.jpg (470.02 KiB) Viewed 5625 times
Tengo que intsalar algo adicional a HMG?
Alguna sugerencia?
Re: ComboSearchGrid
Posted: Wed Sep 24, 2014 4:27 pm
by Javier Tovar
OK, hice la sugerencia que hizo bpd2000 y compila bien, pero no me responde bien, voy a probar y les comento.
Re: ComboSearchGrid
Posted: Fri Sep 26, 2014 12:48 pm
by zorpavns
Thanks!! working
Re: ComboSearchGrid
Posted: Fri Aug 21, 2015 8:54 pm
by zorpavns
I have a problem with ComboSearchGrid. I do not know how to solve . So I asked for help . When you enter the value of the variable . Figure displays outside the window . And when the value is empty doing everything right
