HMG with Edge WebView2
Re: HMG with Edge WebView2
srvet_claudio wrote: Wed Aug 18, 2021 12:17 am Hi,
this is a slightly improved version with more information to detect and solve errors in webview2 runtime.
Hola a todos, tengo algunas dudas, quizá alguno sepa...
Cree una ventana para tener el WhatsApp pero no logro que inicie el "Zoom" a un cierto valor.
Ya modifiqué la configuración de EDGE pero ni así.
Tengo que Oprimir las teclas Ctrl-"+" y Ctrl-"-" (o Ctrl-Scroll Mouse) para agrandar o
reducir el tamaño pero antes debo darle "Click" a la ventana como para "activarla"
Hello everyone, I have some doubts, maybe someone knows ...
I created a window to have the WhatsApp but I can't get it to start the "Zoom" at a certain value.
I already modified the EDGE settings but not like that.
I have to press the keys Ctrl - "+" and Ctrl - "-" (or Ctrl-Scroll Mouse) to enlarge or reduce the size
but first I must give "Click" to the window as to "activate" it
FUNCTION WhatAppsWeb()
	DEFINE WINDOW Win_2 ROW 0 COL 0 WIDTH 500 HEIGHT 600 TITLE "WhatAppsWeb" NOSIZE NOMAXIMIZE CHILD TOPMOST ;
			ON INIT ( Keybd_Event( VK_TAB, .T. ) )	; // SetFocus
			ON GOTFOCUS ( Press2Keys( VK_CONTROL, VK_SUBTRACT ), Press2Keys( VK_CONTROL, VK_SUBTRACT ), Press2Keys( VK_CONTROL, VK_SUBTRACT ) )
	INIT_WEBVIEW2( Win_2.Handle, "https://web.whatsapp.com/" )
	CENTER WINDOW Win_2
    ACTIVATE WINDOW Win_2
FUNCTION Press2Keys( nVK1, nVK2 )
	Keybd_Event( nVK1, .F. )
	Keybd_Event( nVK2, .F. )
	Keybd_Event( nVK2, .T. )
	Keybd_Event( nVK1, .T. )
RETURN nil
Y al seleccionar otro Link de la ventana principal, lo incrusta el la ventana
del WhatsApps ???
And when selecting another Link from the main window, it embeds it in the window
from WhatsApps ???
Si lo hago de otra forma, lo despliega en la ventana principal...
If I do it in another way, it displays it in the main window ...
*INIT_WEBVIEW2( Win_2.Handle, "https://web.whatsapp.com/" )
NAVIGATE_WEBVIEW2( "https://web.whatsapp.com/" )
see this demo (enabled context menu, zoom, get url, devtools, etc)
hmg_webview2_version03.zip
(2.08 MiB) Downloaded 323 times
I've compiled and ran application.
But I'm still thinking for what we can use it?
srvet_claudio wrote: Thu Aug 19, 2021 9:16 pm Hi,
Gracias de nuevo.
Dr. Soto, en que parte viene lo de Zoom ?
Hola Andrés,
El zoom con Ctrl + y Ctrl -
mol wrote: Thu Aug 19, 2021 9:35 pm I've compiled and ran application.
Hi Marek,
It can be another alternative to create portable applications for desktop-mobile.
The whole GUI interface in html/css/javascript and the file/database reading/writing part in C ++ (desktop) and in Java (Android).
Dr. Soto, se puede tener acceso a lo siguiente ?
COREWEBVIEW2_PERMISSION_KIND
Values Descriptions
COREWEBVIEW2_PERMISSION_KIND_UNKNOWN_PERMISSION Indicates an unknown permission.
COREWEBVIEW2_PERMISSION_KIND_MICROPHONE Indicates permission to capture audio.
COREWEBVIEW2_PERMISSION_KIND_CAMERA Indicates permission to capture video.
COREWEBVIEW2_PERMISSION_KIND_GEOLOCATION Indicates permission to access geolocation.
COREWEBVIEW2_PERMISSION_KIND_NOTIFICATIONS Indicates permission to send web notifications.
COREWEBVIEW2_PERMISSION_KIND_OTHER_SENSORS Indicates permission to access generic sensor.
COREWEBVIEW2_PERMISSION_KIND_CLIPBOARD_READ Indicates permission to read the system clipboard without a user gesture.
andyglezl wrote: Thu Aug 19, 2021 7:26 pm And when selecting another Link from the main window, it embeds it in the window
from WhatsApps ???
every time you use INIT_WEBVIEW2 it will create a new Instance
i recommend to use a "PANEL" for Win_2
AUGE_OHR wrote: Fri Aug 20, 2021 5:11 am
from WhatsApps ???
Sucede lo mismo...
The same thing happens ...
Can somebody put sample how to create textbox to input values and grid to display tables with WebView?
