Getfolder()
dominique_devuyst
Re: Getfolder()
Post by dominique_devuyst »
Serge,
The folder path/name is ok (I have a multi language PC!).
I have tried C:\users\Administrateur\ and others folders not in Gebruiker : no problem.
Now, I see a padlock on Gebruiker.
However, I can read/write in the files and subfolders of the folder Gebruiker.
But the access seems blocked (only) for my application : strange!
I have tried to unlock Gebruiker in the properties, without result : it remains locked.
I continue to search for the why.
Dominique
edk
Re: Getfolder()
Post by edk »
Start application in "Run as Administrator" mode and check if you have access to this folder.
dominique_devuyst
Re: Getfolder()
edk wrote: Fri Apr 06, 2018 4:16 pm Start application in "Run as Administrator" mode and check if you have access to this folder.
Hi edk,
I have already tried : it is the same.
He return 'My computer' and not the initpath.
Dominique
edk
Re: Getfolder()
Post by edk »
To which the user corresponds to the name "Gebruiker"? Will it be: Default, Default User, All Users, Public or is it called a local account in Windows?
What is the operating system?
dominique_devuyst
Re: Getfolder()
edk wrote: Tue Apr 10, 2018 11:47 am To which the user corresponds to the name "Gebruiker"? Will it be: Default, Default User, All Users, Public or is it called a local account in Windows?
Hi edk,
The OS is win7
The path is C:\Users\Gebruiker
The users are :
Getfolder() returns the initpath for all folders (and subfolders) except for the folder Gebruiker and its contents.
I have tried to unlock Gebruiker (10 minuts!) but the padlock stay there.
Dominique
Re: Getfolder()
Strange. It must be a naming problem. Edward, what do you think?
Re: Getfolder()
serge_girard wrote: Wed Apr 11, 2018 10:23 am Strange ...
Could this "locked" symbol be pointing to something?
Viva HMG :D
edk
Re: Getfolder()
Post by edk »
It seems to me that, the padlock is not the reason for this behavior of the GetFolder function here.
The C:\USER\Gebruiker folder is in this case a profile folder.
In order for GetFolder to work with this folder, it should be possible to display the profile folder in the window.
Try this code, it works on Windows 10 for me:
#define plik_ini "demo.ini"
PROCEDURE MAIN()
Local cPath:=""
BEGIN INI FILE (plik_ini)
	GET cPath SECTION "Main" ENTRY "Path" DEFAULT ""
END INI
IF EMPTY(cPath)
		SET SECTION "Main" ENTRY "Path" TO "C:\"
	END INI
DEFINE WINDOW main_form ;
	AT 110,220 ;
	WIDTH 335 ;
	HEIGHT 260 ;
	TITLE 'Test';
	MAIN;
	NOMAXIMIZE ;
	NOSIZE
	DEFINE MAIN MENU
		DEFINE POPUP "&File"
			MENUITEM "&Get Folder" ACTION GetFld()
			MENUITEM "E&xit" ACTION Main_form.Release
		END POPUP
	END MENU
Main_form.center
Main_form.activate
FUNCTION GetFld()
Local cPath:=""
END INI
msgbox('InitPath for GetFolder(): ' + cPath )
cPath :=  GetFolder ( 'Get Folder' , cPath, , .T. /* [<lNewFolderButton>] */, .T. /* [<lIncludeFiles>] */, CSIDL_DRIVES + CSIDL_PROFILE /* [<nCSIDL_FolderType>] */ )
IF EMPTY(cPath)
	RETURN Nil
msgbox('Selected Path by GetFolder(): ' + cPath)
	SET SECTION "Main" ENTRY "Path" TO cPath
END INI
Re: Getfolder()
Tal vez en Seguridad...
En la carpeta oprimir Boton derecho / Propiedades / Seguridad
Maybe in Security ...
In the folder, click Right button / Properties / Security
dominique_devuyst
Re: Getfolder()
edk wrote: Wed Apr 11, 2018 2:22 pm It seems to me that, the padlock is not the reason for this behavior of the GetFolder function here.
Try this code, it works on Windows 10 for me ......
Thanks edk,
Getfolder() with your parameters work very fine!
Good to know!
Thank you very much for your help.
Dominique
