"Workarea not in use" Error
asharpham
Post by asharpham »
I have these 2 lines of code:
USE Library NEW
dbGoBottom()
which compiles fine but gives me this runtime error:
"Workarea not in use: DBGOBOTTOM".
I've looked at samples and right through the documentation but can't see why I'm gettiong this error. I would have thought opening the database and then navigating it should work.
Alan
Re: "Workarea not in use" Error
asharpham wrote: Thu Mar 29, 2018 8:01 am I have these 2 lines of code:
USE Library NEW
dbGoBottom()
Alan
Hi Alan
Probably your file "Library" didn't open.
You can use USED() function just after USE command and before any database command / function to test database file is successfully open; and / or FILE() function before USE command to check existence of yor file.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Command USE TABLE NEW
should only appear once in the program
If it's already open it can not again (maybe it can clipper, it can not hmg)
If is possible save problematic program in the zip and add it to the attachment,
it will be easier for everyone who wants to help
asharpham
Post by asharpham »
I did this:
IF USED()
dbGoBottom()
USE Library NEW
dbGoBottom()
but got the same result.
edk
Post by edk »
Try to ask for an open alias before dbGoBottom ().
USE Library NEW
MsgBox( Alias(), 'Active Alias' )
dbGoBottom()
What is the active alias?
Anand
Post by Anand »
asharpham wrote: Thu Mar 29, 2018 10:25 am I did this:
IF USED()
dbGoBottom()
USE Library NEW
dbGoBottom()
Hi asharpham
The correct code is
USE Library NEW
IF USED()
     dbGoBottom()
Anand
Anand
Hi Alan,
I have no problems with this:
USE Library NEW
dbGoBottom()
If this gives error with your file, I think your file is corrupted (long filed name?)
Try to dbcreate it again with :
// ferase('library.dbf')
 aSTRUCT := { {"TRACKNUM","N",4,0 }, ;
 {"ALBUM_NO","C",6,0}, ;
 {"ALBUM_TITL","C",40,0}, ;
 {"TITLE","C",33,0}, ;
 {"ARTIST","C",40,0}, ;
 {"ART_NO","N",4,0}, ;
 {"TRACK","N",2,0}, ;
 {"DUR","C",5,0}, ;
 {"YR","C",2,0}, ;
 {"FILENAME","C",8,0} }
dbCreate("LIBRARY",aSTRUCT)
USE Library NEW
msginfo(alias())
dbGoBottom()
Dbf file names are not delimited to 8 characters now
No, but fieldnames? I think:problem when reading...
