HMG_HPDF - Export to PDF made easy...
Re: HMG_HPDF - Export to PDF made easy...
Post by EduardoLuis »
Hi Edward:
Unfortunatly i could not make it work.-
Some questions:
1.- I must have installed your previously new_functions zip ??
2.- About 1, i've download and when i try to decompile it give errors.-
3.- When rebuild library i must rebuild ANSI and Unicode or only ANSI ???
If you please tell me how to perform your excellent work.-
With regards.
Eduardo
edk
Post by edk »
Hola Eduardo.
Ad.1. For latest functions (Skew, Scaled, Rendered, Circled), you do not need to have the previous New_features.7z installed, but if you want to use the previous new functions, you should have them installed.
Ad.2. What kind of errors?
Ad.3. Personally, I use Unicode.
OK.
I will try to describe step by step:
1. The hmg_hpdf.zip file should be unpacked. The hmg_hpdf.ch file will be created, which should be copied to the "INCLUDE" folder of the HMG 3.4.4 installation, eg C:\hmg.3.4.4\INCLUDE (contains the previous and the newest commands)
hmg_hpdf.zip
(5.39 KiB) Downloaded 328 times
2. The h_HMG_HPDF.zip file should be unpacked. The h_HMG_HPDF.Prg file will be created, which should be copied to the "SOURCE" folder of the HMG 3.4.4 installation, eg C:\hmg.3.4.4\SOURCE (contains previous and new functions)
h_HMG_HPDF.zip
(12.92 KiB) Downloaded 290 times
3. The demo.zip file should be unpacked. The Demo.prg file will be created, which should be copied to the "SAMPLES\HPDF\Demo1" folder of the HMG 3.4.4 installation, eg C:\hmg.3.4.4\SAMPLES\HPDF\Demo1
Demo.zip
(1.58 KiB) Downloaded 333 times
4. From the HMG installation folder 3.4.4 rebuild HMG using BuildLib32.bat, eg C:\hmg.3.4.4\BuildLib32.bat (using eg UNICODE- default)
5. From the HMG 3.4.4 installation folder, run the demo in the "SAMPLES\HPDF\Demo1" folder by running the Build.bat file, eg C:\hmg.3.4.4\SAMPLES\HPDF\Demo1\Build.bat
Hi Edward:
First thanks for your crystal clear explanation, after send you this respond, i'll follow your suggestions.-
Error - after performing compilation under 3.4.4 Ide - says:
Date:03/12/18 Time: 16:07:53
Error BASE/1081 Argument error: +
Called from _HMG_HPDF_SEEKHARUFONTS(1818)
Called from _HMG_HPDF_SETFONT(1756)
Called from HPDF_RENDERTEXT(357)
Called from MAIN(83)
Perhaps you can have a better idea.-
With regards.
Eduardo
Hi Edward:
All works like a charm. Absolutly OK.-
Again, thanks for your explanation, efforts, and to share with us all your knowledge.-
With regards.
Eduardo
edk
Post by edk »
EduardoLuis wrote: Mon Mar 12, 2018 7:13 pm Error - after performing compilation under 3.4.4 Ide - says:
With regards.
Eduardo
Everything was explained :lol: :
edk wrote: Mon Mar 05, 2018 8:30 pm New features:
HMG HPDF
HPDFPRINT command improvements:
New commands:
:arrow: Removal of noticed bugs.
Edward, how to get following result
edk
Post by edk »
Do you mean something like this ?:
Bez tytułu1.png (14.83 KiB) Viewed 5233 times
Replace the HPDF_CircleText function with this one (by the way, I corrected the rims color error if the color was not defined.):
Function HPDF_CircleText( nRow, nCol, cFontName, nFontSize, nRColor, nGColor, nBColor, cText, lBold, lItalic, lColor, lFont, lSize, nRadial, lCircle, cAlign)
/* text along a circle */
/* nRow, nCol wspolrzedne srodka */
Local nAngle1, nAngle2, nRlen
Local i, nRad1, nRad2, x, y
Local oFont := Nil
Local cFont := ''
Local hPdf        := _HMG_SYSDATA[ 150 ][ 1 ]
Local hPage       := _HMG_SYSDATA[ 150 ][ 7 ]
*Local nWidth      := _HMG_SYSDATA[ 150 ][ 4 ]
Local nHeight     := _HMG_SYSDATA[ 150 ][ 5 ]
Local nxPos       := _HMG_HPDF_MM2Pixel( nCol )
Local nyPos       := nHeight - _HMG_HPDF_MM2Pixel( nRow )
Local nPxAng
Local nRange     := 360
DEFAULT lCircle     := .F.
DEFAULT nRadial     := 15
default cFontName := ''
default nFontSize := _HMG_SYSDATA[ 150 ][ 9 ]
default nRColor := 0
default nGColor := 0
default nBColor := 0
default lBold := .f.
default lItalic := .f.
default lColor := .f.
default lFont := .f.
default lSize := .f.
DEFAULT cText := ""
DEFAULT cAlign :=""
IF !HB_IsNumeric( nRadial )
	nRadial := 15
IF !HB_IsString( cAlign )
	cAlign := ""
nRLen:= _HMG_HPDF_MM2Pixel( nRadial )
// set color
If lColor
   HPDF_Page_SetRGBFill( hPage, nRColor/255, nGColor/255, nBColor/255 )
   HPDF_Page_SetRGBFill( hPage, 0.0, 0.0, 0.0 )
endIf
IF lCircle
	If lColor
		HPDF_Page_SetRGBSTROKE( hPage, nRColor/255, nGColor/255, nBColor/255 )
		HPDF_Page_SetRGBSTROKE( hPage, 0.0, 0.0, 0.0 )
	endIf
	HPDF_Page_SetLineWidth (hPage, 1.5)
	HPDF_Page_Circle ( hPage, nxPos, nyPos, nRlen + nFontSize)
	HPDF_Page_Circle ( hPage, nxPos, nyPos, nRlen - (nFontSize /3))
	HPDF_Page_Stroke ( hPage )
	HPDF_Page_SetLineWidth (hPage, 1)
// set font
cFontName := AllTrim(_HMG_HPDF_SetFont( cFontName, lBold, lItalic ))
if HMG_UPPER (cFileExt (cFontName)) == '.TTF' // load ttf font
	cFont := HPDF_LOADTTFONTFROMFILE( hPdf, cFontName, .t. )
	If HMG_LEN( alltrim( cFont ) ) == 0
		_HMG_HPDF_Error( 6 , cFontName )
	oFont := HPDF_GetFont( hPdf, cFont, _HMG_SYSDATA[ 150 ][ 10 ] )
	If HMG_UPPER( alltrim( cFontName ) ) == "SYMBOL" .or. HMG_UPPER( alltrim( cFontName ) ) == "ZAPFDINGBATS"
		oFont := HPDF_GetFont( hPdf, cFontName, Nil )
		oFont := HPDF_GetFont( hPdf, cFontName, _HMG_SYSDATA[ 150 ][ 10 ] )
	endIf
If oFont == Nil
EndIF
HPDF_Page_SetFontAndSize( hPage, oFont, nFontSize )
SWITCH HMG_UPPER( alltrim( cAlign ) )
	CASE "TOP"   ; nRange := 180 ; EXIT		//Uppper
	CASE "BOTTOM"  ; nRange := 180 ; EXIT   	//Bottom
ENDSWITCH
nAngle1 := nRange / Len( cText )	//monospaced fonts
nAngle2 := 180
//A better solution for non monospaced fonts.
nPxAng := nRange / HPDF_Page_TextWidth( hPage, cText )
HPDF_Page_BeginText ( hPage)
FOR i=1 TO LEN(cText)
	nRad1 := ( nAngle2 - Int((HPDF_Page_TextWidth( hPage, SUBSTR(cText, i, 1) ) * nPxAng) / 2) - 90) / 180 * 3.141592
	nRad2 := nAngle2 / 180 * 3.141592
		CASE "BOTTOM"
			x := nxPos + cos(nRad2) * (nRlen + nFontSize*(2/3))
			y := nyPos - sin(nRad2) * (nRlen + nFontSize*(2/3))
			HPDF_Page_SetTextMatrix( hPage, cos(nRad1), -sin(nRad1), sin(nRad1), cos(nRad1), x, y)
			EXIT
		OTHERWISE
			x := nxPos + cos(nRad2) * nRlen
			y := nyPos + sin(nRad2) * nRlen
			HPDF_Page_SetTextMatrix( hPage, cos(nRad1), sin(nRad1), -sin(nRad1), cos(nRad1), x, y)
	ENDSWITCH
	HPDF_Page_ShowText ( hPage, SUBSTR(cText, i, 1) )
	//nAngle2 -= nAngle1		//monospaced fonts
	nAngle2 -= (HPDF_Page_TextWidth( hPage, SUBSTR(cText, i, 1) ) * nPxAng)
NEXT i
HPDF_Page_EndText ( hPage )
RETURN Nil
Replace #xcommand @ <Row>, <Col> HPDFPRINT CIRCLED TEXT with this one:
#xcommand @ <Row> , <Col> HPDFPRINT CIRCLED TEXT <cText> ;
	[ <lfont : FONT> <cFontName> ] ;
	[ <lsize : SIZE> <nFontSize> ] ;
	[ <bold : BOLD> [ IF <lBold> ] ] ;
	[ <italic : ITALIC> [ IF <lItalic> ] ] ;
	[ <lcolor : COLOR> <aColor> ] ;
 	[ <lrad : RADIUS> <nRad> ] ;
	[ <lrims: RIMS> ] ;
	[ <align : TOP, BOTTOM> ] ;
	HPDF_CircleText ( <Row> , <Col> , <cFontName> , <nFontSize> , <aColor>\[1\] , <aColor>\[2\] , <aColor>\[3\] , <cText> ,;
		<.bold.> .AND. iif( HB_IsLogical(<lBold>), <lBold>, HB_IsNil(<lBold>) ) ,;
		<.italic.> .AND. iif( HB_IsLogical(<lItalic>), <lItalic>, HB_IsNil(<lItalic>) ) ,;
		<.lcolor.> , <.lfont.> , <.lsize.> , <nRad> , <.lrims.> , <"align">)
In your source, use the commands:
@ 230 , 160 HPDFPRINT CIRCLED TEXT "TIPSQUIRREL" FONT "Times" SIZE 20 BOLD RADIUS 20 RIMS TOP
@ 230 , 160 HPDFPRINT CIRCLED TEXT "  "+chr(149)+"  PS NUTS  "+chr(149)+"  " SIZE 20 BOLD RADIUS 20 BOTTOM
where:
TOP - prints the text in the upper half of the circle
BOTTOM - prints the text in the bottom half of the circle
Edward.
WOW!
Thank you Edward, now we can play 360 degree
Hi Edward:
Again: WOOOOOOWWWWWWW
Excellent.- With these new functions PDF get all the possible power.-
Thanks for your effort.-
With regards.
Eduardo
Wonderful!
EDward, Can you make it work for unicode encoding also? Especially Indian languages?
