HMG_HPDF - Export to PDF made easy...
Re: HMG_HPDF - Export to PDF made easy...
Hi EDK:
My first impression WOOOOWWWWWWW.-
Excellent contribution.-
Thanks for share.-
Eduardo
Thanks for share.-
Eduardo
I have still problems after this patch ...
My problem is that I need to measure text length and fit it in the rectancle with constant width and various height.
I found such a method to measure text width in C++, but I'm not familiar with this language to adapt this solution to HMG.
Maybe BosTaurus library could be used to do that?
VOID Example_MeasureString(HDC hdc)
Graphics graphics(hdc);
// Set up the string.
WCHAR string[] = L"Measure Text";
Font font(L"Arial", 16);
RectF layoutRect(0, 0, 100, 50);
RectF boundRect;
// Measure the string.
graphics.MeasureString(string, 12, &font, layoutRect, &boundRect);
// Draw a rectangle that represents the size of the string.
graphics.DrawRectangle(&Pen(Color(255, 0, 0, 0)), boundRect);
+1EduardoLuis wrote: ↑Mon Mar 05, 2018 9:38 pm Hi EDK:
Thanks for share.-
Eduardo
Is it the way to set default interline in PDF file?
When I use multiline text printing, I'm not able to detect whole area height
Hi Mol:
The command to manage multiline spacing is:
SET HPDFPAGE LINESPACING TO N
N: corresponds to pixels
If you don't need to modify, you must specify this when you create HPDFDOC
Hopping this helps you
With regards
Eduardo
With regards
Eduardo
Hi EDK:
After looking all HARU i try unsuccesfully to replicate the types that appear on attached pdf page.
Searching for that controls they exist on HPDF library.
- haru_sample.zip
- (5.03 KiB) Downloaded 262 times
Marek, try this:mol wrote: ↑Tue Mar 06, 2018 9:39 am I have still problems after this patch ...
VOID Example_MeasureString(HDC hdc) { Graphics graphics(hdc); // Set up the string. WCHAR string[] = L"Measure Text"; Font font(L"Arial", 16); RectF layoutRect(0, 0, 100, 50); RectF boundRect; // Measure the string. graphics.MeasureString(string, 12, &font, layoutRect, &boundRect); // Draw a rectangle that represents the size of the string. graphics.DrawRectangle(&Pen(Color(255, 0, 0, 0)), boundRect); }
lBold := .T.
cText := "This is a sample Text."
cFont := "Arial Narrow"
nFtnSize := 24
@120, 20 PRINT cText FONT cFont SIZE nFtnSize BOLD IF lBold
@130, 20 PRINT LINE TO 130, 20 + HMG_GetTextWidthinMM (OpenPrinterGetPagedc(), cText, cFont, nFtnSize, lBold)
FUNCTION HMG_GetTextWidthInMM (hDC, cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout)
Local hFont
Default cText:=""
Default cFontName := _HMG_SYSDATA [ 342 ]
Default nFontSize := _HMG_SYSDATA [ 343 ]
Default lItalic := .F.
Default lUnderline := .F.
Default lStrikeout := .F.
Default lBold := .F.
hFont := HMG_CreateFont (hDC, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeOut )
RETURN (GetTextWidth( hDC, cText, hFont ) * 25.4 ) / HMG_GetPrinterResolution( hDC )[1]
FUNCTION HMG_GetTextWidthInPx (hDC, cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout)
Local hFont
Default cText:=""
RETURN GetTextWidth( hDC, cText, hFont )
#pragma begindump
#include <windows.h>
#include <hbapi.h>
HB_FUNC ( HMG_GETPRINTERRESOLUTION )
hb_reta (2);
hb_storvni ( GetDeviceCaps( (HDC) hb_parnl (1), LOGPIXELSX ), -1, 1 );
hb_storvni ( GetDeviceCaps( (HDC) hb_parnl (1), LOGPIXELSY ), -1, 2 );
#pragma ENDDUMP
For HPDF:
@ 20, 10 HPDFPRINT "This is a sample Text in ITALIC." ITALIC
@ 20, 10 HPDFPRINT RECTANGLE TO 26, 10 + HMG_GetPDFTextWidth ("This is a sample Text in ITALIC.", /* Default font */ , /* Default font size */ , /* Bold */, .T. /* Italic */)
FUNCTION HMG_GetPDFTextWidth (cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout)
Local cFont, oFont, nWidth
default cFontName := _HMG_SYSDATA[ 150 ][ 8 ]
default nFontSize := _HMG_SYSDATA[ 150 ][ 9 ]
default lBold := .f.
default lItalic := .f.
default lUnderline := .f.
default lStrikeout := .f.
If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found!
_HMG_HPDF_Error( 3 )
Return 0
If _HMG_SYSDATA[ 150 ][ 7 ] == Nil // PDF Page object not found!
_HMG_HPDF_Error( 5 )
Return 0
cFontName := AllTrim(_HMG_HPDF_SetFont( cFontName, lBold, lItalic ))
if HMG_UPPER (cFileExt (cFontName)) == '.TTF' // load ttf font
cFont := HPDF_LOADTTFONTFROMFILE( _HMG_SYSDATA[ 150 ][ 1 ], cFontName, .t. )
If HMG_LEN( alltrim( cFont ) ) == 0
_HMG_HPDF_Error( 6 , cFontName )
Return 0
oFont := HPDF_GetFont( _HMG_SYSDATA[ 150 ][ 1 ], cFont, _HMG_SYSDATA[ 150 ][ 10 ] )
If HMG_UPPER( alltrim( cFontName ) ) == "SYMBOL" .or. HMG_UPPER( alltrim( cFontName ) ) == "ZAPFDINGBATS"
oFont := HPDF_GetFont( _HMG_SYSDATA[ 150 ][ 1 ], cFontName, Nil )
oFont := HPDF_GetFont( _HMG_SYSDATA[ 150 ][ 1 ], cFontName, _HMG_SYSDATA[ 150 ][ 10 ] )
endIf
If oFont == Nil
Return 0
Else
HPDF_Page_SetFontAndSize( _HMG_SYSDATA[ 150 ][ 7 ], oFont, nFontSize )
nWidth := _HMG_HPDF_Pixel2MM( HPDF_Page_TextWidth( _HMG_SYSDATA[ 150 ][ 7 ], cText ) )
Endif
Return nWidth
Hola Eduardo, mi tocayo.EduardoLuis wrote: ↑Tue Mar 06, 2018 1:19 pm Hi EDK:
Unfortunately, these controls are not in HMG HPDF.
It seems to me that once I had it done. But I can not find it on the computer.
I will look into old machines, maybe it has survived somewhere.
If I do not find it, I will try to develop it in my spare time.
Stay tuned.
Edward.
Hi Edward (EDK)
You are not only wise, you are a multilanguage man.
About my previous post, some time ago i found this HARU code associated with text inside a circle.-
I suppose it's oriented to C, and my knowledge on that language is too poor.
I try to implement it, but lots of error become like a rain.-
I copy behind part of the code, and perhaps this give's you a better idea.-
With regards, as allways.
Eduardo
/* text along a circle */
HPDF_Page_SetGrayStroke (page, 0);
HPDF_Page_Circle (page, 210, 190, 145);
HPDF_Page_Circle (page, 210, 190, 113);
HPDF_Page_Stroke (page);
angle1 = 360 / (strlen (SAMP_TXT));
angle2 = 180;
HPDF_Page_BeginText (page);
font = HPDF_GetFont (pdf, "Courier-Bold", NULL);
HPDF_Page_SetFontAndSize (page, font, 30);
for (i = 0; i < strlen (SAMP_TXT); i++) {
char buf[2];
float x;
float y;
rad1 = (angle2 - 90) / 180 * 3.141592;
rad2 = angle2 / 180 * 3.141592;
x = 210 + cos(rad2) * 122;
y = 190 + sin(rad2) * 122;
HPDF_Page_SetTextMatrix(page, cos(rad1), sin(rad1), -sin(rad1), cos(rad1), x, y);
buf[0] = SAMP_TXT;
buf[1] = 0;
HPDF_Page_ShowText (page, buf);
angle2 -= angle1;
HPDF_Page_EndText (page);
/* save the document to a file */
HPDF_SaveToFile (pdf, fname);
Eduardo
angle2 = 180;
char buf[2];
float x;
float y;
buf[0] = SAMP_TXT;
buf[1] = 0;
angle2 -= angle1;
