How to get parameters passed to function
Hi guys!
I want to log parameters passed to function in situation when program crashes.
We can retrive path to error using this code
	cLog := ""
	i := 2
	while ( !Empty(ProcName(i)) )
		cLog += ProcName(i) + "(" + alltrim(str(ProcLine(i)) + ")"+CRLF
		i++
	end
but, how to retrieve variables in ProcName(i) ?
It's realized in debugger, but I don't know how to find it.
Re: How to get parameters passed to fiunction
Have you gone through the debugger coding by Claudio distributed along with HMG?
I've extracted some code from Claudio debugger and it works super! This code generates only PRIVATE, I'll modify it later for optionally show LOCAL and GLOBAL
#include "hbmemvar.ch"
function ShowVariables
	local aBVars := {}
	local cName := ""
	local i
	local hSkip
	local m
	local nCount
	local xValue
	local cLog := ""
	i := 2
		aBVars := {}
		nCount := __mvDbgInfo( HB_MV_PRIVATE )
		IF nCount > 0
			m := __mvDbgInfo( HB_MV_PRIVATE_LOCAL, i )
			hSkip := { => }
			hb_HAllocate( hSkip, nCount )
			FOR n := nCount TO 1 STEP -1
				xValue := __mvDbgInfo( HB_MV_PRIVATE, n, @cName )
				IF ! cName $ hSkip
					AAdd( aBVars, { cName, xValue, Iif( m > 0, "Private LOCAL", "Private GLOBAL" ), Iif( m > 0, i, 0 ) } )
					hSkip[ cName ] := NIL
				--m
		cLog += ProcName(i)+CRLF
		for m := 1 to len(aBVars)
			cLog += chr(9)+hb_valtoexp(aBVars[m])+CRLF
		next m
		i++
	end
return cLog
Re: How to get parameters passed to function
I can't find solution for retrieving local variables :-( Maybe Claudio will help
Hi Marek,
compile with /b and call in your app:
aVars := HMG_Debugger():GetVars( nil, nil, lShowPublics, lShowPrivates, lShowStatics, lShowLocals )
MsgDebug (aVars)
mol wrote: Sat Oct 07, 2017 6:00 am Is it possible to get it without debugger?
I do not know, is need to investigate the structure of the stack of local variables
There is __DbgEntry in debugger, which builds stack.
Array of Local variables is third parameter of this function.
But,I didn't found any call of this function. Is it wrong direction?
the debugger functions of hb only link when compiled with /b
