Activex Sample
Re: Activex Sample
Yes! Fantastic.
- luisvasquezcl
Re: Activex Sample
Hi Esgici
do you have install openoffice?.
I Try to open a document .swx and i can not.
- esgici
Re: Activex Sample
Hola Luisluisvasquezcl wrote:do you have install openoffice?.
Of course !
Without proper program IE does can't anything.
f.e. if MS-Office not installed we also can't open word, excel... etc files with Activex control.
In fact IE too calls appropriate program for open files.
Viva INTERNATIONAL HMG
Re: Activex Sample
I am using OpenOffice.org 2.4 version. I can open .ods .odt (open document spreadsheet/text) easily.
Re: Activex Sample
When in modal window, the above sample gives error and breaks in the middle if nothing is opened and just closed. For example, compile the following code and enter the modal window by clicking "click here" and just close the window by either clicking [x] or clicking menu 'test -> exit'
* Copyright 2002-2008 Roberto Lopez <harbourminigui@gmail.com>
* http://harbourminigui.googlepages.com/
* Activex Sample: Inspired by Freewin Activex inplementation by
* Oscar Joel Lira Lira (http://sourceforge.net/projects/freewin).
#include "minigui.ch"
FUNCTION Main()
Public lOpen := .F.
define window win2 at 0,0 width 800 height 500 main
define button activex
row 10
col 10
width 80
caption "Click Here"
action modalactivex()
end button
end window
win2.center
win2.activate()
return nil
function modalactivex
DEFINE WINDOW Win1 ;
WIDTH 800 ;
HEIGHT 500 ;
TITLE 'HMG ActiveX Support Demo' ;
modal ;
ON PAINT ( Win1.Test.Width := Win1.Width - 28,;
Win1.Test.Height:= Win1.Height- 95 )
DEFINE MAIN MENU
POPUP "Test"
MENUITEM "Open file" ACTION Test()
MENUITEM "Close file" ACTION Win1.Test.Object:Navigate("about:blank")
SEPARATOR
MENUITEM "Exit" ACTION Win1.Release
END POPUP
END MENU
DEFINE LABEL LABEL_1
ROW 0
COL 10
WIDTH 80
HEIGHT 24
VALUE "Http:"
END LABEL
DEFINE TEXTBOX TEXT_1
ROW 0
COL 100
WIDTH 300
HEIGHT 24
VALUE ""
END TEXTBOX
DEFINE BUTTON BTN_1
ROW 0
COL 400
WIDTH 24
HEIGHT 24
CAPTION "Go"
ACTION Win1.Test.Object:Navigate( Win1.Text_1.Value )
END BUTTON
DEFINE ACTIVEX Test
ROW 30
COL 10
WIDTH 700
HEIGHT 380
PROGID "shell.explorer.2"
END ACTIVEX
Center Window Win1
Activate Window Win1
Procedure Test()
local cFile := GetFile({{'Excel','*.xls'},;
{'Word','*.doc'},;
{'PowerPoint','*.ppt'},;
{'All files','*.*'}})
if Len( cFile ) > 0
Win1.Test.Object:Navigate( cFile )
//Win1.Title := Win1.Test.Object:Document:Name
Win1.Test.Object:Navigate( "about:blank" )
