I need sample calendar application...
I need an idea how to write application to plan some events in time. Not only day of begin, but minutes are important.
Maybe someone has an idea how to save event date and time and control if another event occupies the same term?
Regards, Marek
Re: I need sample calendar application...
Post by EduardoLuis »
Hi Marek:
Some time ago i need to do an app that will make what you are looking.- As the client desists from continuing our relationship, i abandoned the project.-
But the way i found was develope a table (1 reg for calendar appointment) in which i have to fields: one for date and hour of the begining event, and other for date and hour of ending event.- Each field contents the following format (character):
yearmonthdayhourminutes, for example "201707251535".- The table have's two associated index, so search for and specific appointment will become easy a quick.-
Obviously the project i abandoned have's a graphical sheet per day or week that show event description in labeled colors.-
I attach a screen that shows how will look the app.
Hopping this gives you and idea.-
With regards.
Eduardo
martingz
Post by martingz »
Marek , im start a special scheduler , if you want i send sources
[image][/image]
martingz wrote: Tue Jul 25, 2017 2:34 pm Marek , im start a special scheduler , if you want i send sources
[image][/image]
Hi Martin
Please don't SEND, simply SHARE ;)
Viva SHARED HMG :D
martingz
Post by martingz »
Esgici, Marek is in Mega
https://mega.nz/#!YxxBXD5a!NxliJ1IZfwYO ... xPYwbNKI3I
https://mega.nz/#!9gYlEAbI!355LygDG7k7f ... _odBFaEZkg
https://mega.nz/#!lkpyxZrJ!A_h3TnAAnkJC ... 9esm5lS2ek
I upload sources, exex, libs, and strcucture and data , if not have installed Mysql o Mariadb , you have to install, this is work in progress, tables
are in production. If connect be careful, we work on it
regrads
sorry for my bad english
Esgici, Marek esta en Mega
Subi fuentes,ejecutables, librerias, y las estructuras con datos para importar, Si no tienes intsalado Mysql o Maridb , tiene que bajarlo e instalarlo, e importar los datos, si trabajan con la informacion que trae , sean cuidadosos esta en produccion
martingz
Post by martingz »
You can view daily, weekly or monthly
martingz wrote: Tue Jul 25, 2017 3:42 pm ...
Thanks Martin Gonzales :)
BTW your English is superb; because I understand everything you wrote :arrow:
Viva shared HMG :D
martingz
Post by martingz »
is my frist work whit Mysql, some code embarrasses me, i already know more about how to make better queries,
But the client did not pay, so I remain unfinished
Do you accept events lasting longer than 1 day?
