Spell Check Using Word
Spell Check Using Word is possible, the condition is Word must be installed
Tested on winxp and word 2007 only
Pablo César may further upgrade / modify
// bpd2000
// THIS EXAMPLE IS NEARLY FINISHED
//http://cuinl.tripod.com/Tips/off5.htm              // based on this
//http://www.contactez.net/support/vbscript.html
//https://www.foxite.com/archives/word-spell-check-0000139859.htm
#xcommand TRY              => bError := errorBlock( {|oErr| break( oErr ) } ) ;;
                              BEGIN SEQUENCE
#xcommand CATCH [<!oErr!>] => errorBlock( bError ) ;;
                              RECOVER [USING <oErr>] <-oErr-> ;;
#xcommand FINALLY => ALWAYS
    STATIC oWord
    FUNCTION main()
    LOCAL cText := "Wouldd you be soo kind to showa us how to usea the word spelll checker with HMG. Thank's in advaance."
    MsgInfo(SpellCheck(cText),"Grammar Check")
    RETURN nil
    STATIC FUNCTION SpellCheck(Texto)
    LOCAL oDoc,oTexto
    LOCAL cText:=Texto
    LOCAL lOldGramm
    LOCAL lOldUpper
    IF .NOT. IsWord()
       MsgInfo("MS Word is not installed in your computer.")
       RETURN .F.
    oWord := CreateObject( "Word.Application" )
    oWord:Visible := .F.
    oWord:Documents:Add()
    oWord:Selection()
    oWord:Selection:TypeText(cText)
    lOldGramm := oWord:Options:CheckGrammarAsYouType()
    oWord:Options:CheckGrammarWithSpelling := .F.
    lOldUpper := oWord:Options:IgnoreUppercase()
    oWord:Options:IgnoreUppercase := .F.
    oWord:ActiveDocument:CheckSpelling()
    oWord:Selection:WholeStory()
    oWord:Selection:Copy()
    cText := oWord:Selection:Text()
    //‘Reset options and close everything
    oWord:Options:CheckGrammarAsYouType := lOldGramm
    oWord:Options:IgnoreUppercase := lOldUpper
    oWord:ActiveDocument:Close(0)
    oWord:Quit()
    oWord := Nil
    oTexto := NIL
    oDoc   := NIL
    oWord  := NIL
    IF ! EMPTY(cText) // If ctext is empty that means that the process was canceled
        Texto := cText
    RETURN(Texto)
    FUNCTION isWord()
    local lSuccess:=.F.
    local oWord
    TRY
       oWord:= createObject("word.Application")
       lSuccess:=.T.
    CATCH
       lSuccess:=.F.
    END
    RETURN lSuccess
Re: Spell Check Using Word
Nice Dave !
I will revise it SAP :)
Great !
To get it working I had to change :
MsgInfo(SpellCheck(cText),“Grammar Check”) // use quotes or double quotes
AND
I had to have open Word on forehand.
