Encrypted Password
- mustafa
Encrypted Password
Hola amigos
Les dejo una pequeña aplicación de Password
Mejorado del Sample Enciptado con distintos
usuarios autorizados que Vd. tiene que crear.
Ver
viewtopic.php?f=24&t=3574&p=32880&hilit=password#p32880
Nuevas Opciones
Puede elejir Fotografia del Nuevo usuario
y el Acceso del Nivel mediante los tres colores del
Semaforo.
Para iniciar
Username: Admin
Carge: General Manager
Password: Admin
Vea ejemplo en Carpeta Help
Ver Tambien
viewtopic.php?f=5&t=887&hilit=password
viewtopic.php?f=5&t=887&p=40578&hilit=password#p40578
viewtopic.php?f=9&t=3590&p=33352&hilit=password#p33352
que lo disfruten
*------------------- Google ---------------------*
Hello friends
I leave a small application Password
Improved Sample Enciptado with different
authorized users that you. have to create.
View
new Options
You can choose Photographs of New User
and Access Level by the three colors
Semaphore light.
To start:
Username: Admin
Password: Admin
See example Folder Help
View
enjoy it
Musta
Ver
Nuevas Opciones
Semaforo.
Para iniciar
Username: Admin
Password: Admin
Ver Tambien
que lo disfruten
Hello friends
View
new Options
Semaphore light.
To start:
Username: Admin
Password: Admin
View
enjoy it
Musta
- Password_Restricted_Access.zip
- (2.77 MiB) Downloaded 452 times
- Screenshot.jpg (158.51 KiB) Viewed 6173 times
Re: Encrypted Password
Hi Mustafa:
Nice sample. Thanks for share.-
Eduardo
Hola Mustafa:
Buen ejemplo. Gracias por compartirlo
Eduardo
Eduardo
Hola Mustafa:
Eduardo
- esgici
Gracias amigomustafa wrote: ...
authorized users...
Viva HMG
Viva INTERNATIONAL HMG
Gracias Mustafa por los aportes en HMG !!!!!
Gracias por compartir, Niza creación
Excelente trabajo Mustafá. Muchas gracias
thanks for sharing!
Checkbox "view password" works strange - when is checked, password is encrypted, when uncheck - password is decrypted.
is user name field defined as password, too?
How can I login to
How can I login to
- mustafa
Hola amigo Mol
No entiendo muy bien su pregunta, perdone por no entender ingles y
traduzco del español de Google.
Le presento un grafico haber si puedo entender su preguna.
1º Es la pantalla incial que nos pide el Username, Charge y Password por defecto
CHECKBOX esta en .T. para que en la próxima pantalla 2º se vea el TEXTBOX el
PASSWORD .T. y el usuario escribe Username y Password y con el COMBOBOX elije
el Charge de usuario.
3º en esta Pantalla el usuario desmarca CHECKBOX y lo deja en .F. y verifica si
Username y Password estan bien escritos.
Solo hay Tres intentos de acierto que en cada Error se borra el contenido de
los TEXTBOX.
Si está el CHECKBOX en .F. se pone el TEXTBOX en -> READONLY .T. (solo lectura)
4º En esta pantalla solo está creada para que el usuario vea arriba el Nombre
de usuario la Fotografía y Semáforo de Nivel de Acceso con el Botton "Go Ahead"
que solo te permite seguir adelante.
Espero que mi explicación despeje sus dudas
Un cordial saludo.
Hello friend Mol
Do not quite understand your question, excuse me for not understanding English and
I translate from Spanish by Google.
I present a graph have if I understand your inquiry.
1º is the initial screen that asks us the Username, and Password Default Charge
CHECKBOX was .T. so you can see the TEXTBOX on the next screen 2º the
PASSWORD .T. and the user username and password and choose the COMBOBOX
Charge of the user.
3º in this screen the user uncheck CHECKBOX and leaves it in .F. and see if
Username and Password are well written.
There are only three attempts to hit that every error is cleared content
the TEXTBOX.
If the checkbox in .F. It puts the TEXTBOX in -> READONLY .T. (read only)
4º This screen is only created for the user to look up the name
Photography and User Access Level Semaphore with Botton "Go Ahead"
which only lets you move forward.
I hope my explanation clear your doubts
A cordial greeting.
los TEXTBOX.
Un cordial saludo.
Hello friend Mol
Charge of the user.
the TEXTBOX.
A cordial greeting.
- Password.jpg (51.05 KiB) Viewed 5954 times
