Ado Sample / ejemplo Ado
luisvasquezcl
Re: Ado Sample / ejemplo Ado
Post by luisvasquezcl »
Estimado, Que error de arroja?.
quartz565
Post by quartz565 »
Thank you Luis for sharing !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Steed
Post by Steed »
Thanks, works fine
For w10, and Office 2013 (64 Bits)
I has to modify the stri ng conection as show below
oConexion:ConnectionString ='Provider=Microsoft.ACE.OLEDB.12.0;'+;
but it work ok
Ed
Ismach
Post by Ismach »
My code is:
     Local Rs as Object
     Local ccSQL:=""
     oPConn:= TOleauto():New('Adodb.Connection')
     oPConn:ConnectionString="Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\myapps\gestab\versiones\L400;Extended Properties=Paradox 4.x;"
     // oPConn:ConnectionString="Provider=Microsoft.ACE.OLEDB.12.0;Data Source=c:\myapps\gestab\versiones\L400;Extended Properties=Paradox 4.x;"
     oPConn:Open()
     ccSQL  := "Select Nutab, 01040, Arb82, Arb83, Arb84, Arb85 From Y932ST.db order by Nutab, ARB82;"
     Rs := TOleauto():New('Adodb.recordset')
     Rs:CursorLocation = adUseClient
     Rs:Open( ccSQL , oPConn, adOpenDynamic, adLockReadOnly )
     if  Rs:State = adStateClose
         Msgstop('Failed open table Tabla1')
     Endif
Ismach
Post by Ismach »
the error is:
Date:07/11/18 Time: 17:10:34
Error WINOLE/1007 No se pudo encontrar el archivo ISAM instalable. (0x80004005): Microsoft Access Database Engine (DOS Error -2147352567)
Called from TOLEAUTO:OPEN(0)
Called from POX_CONNECT(50)
Called from MAIN(37)
