Menu_Pizza_SQlite
- mustafa
Menu_Pizza_SQlite
Hola amigos:
Les dejo un pequeño sample que simula el control
y confección de un Menú de una Pizzeria.
He utilizado la basa de datos SQlite
Gracias a las enseñanzas de los maestros:
Sudip , Rathinagiri, Amarante, Mol, Foued,
Qatan, Claudiotedesco,Dragancesu
Perdón si me dejo algún compañero por mencionar.
Para mi el tema de Sqlite creo que tendría que
ampliarse en este foro un poco para los que
no lo conocemos apenas y estamos empezando.
Ruego lean el fichero -> "Read_me_help.txt"
donde se explica un poco como funciona el sample.
Un saludo
*------------------------------- Google --------------------------------------*
Hello friends
I leave a small sample that simulates control
and preparation of a menu from a Pizzeria.
I used the data based SQlite
Thanks to the teachings of the masters:
Sudip, Rathinagiri, Amarante, Mol, Foued,
Qatan, Claudiotedesco, Dragancesu.
Sorry if I let a colleague to mention.
For me the issue would have to think Sqlite
extended in this forum a bit for that
we do not know and we are just beginning.
Pray read the file -> "Read_me_help.txt"
which it explains a bit like the sample works.
a greeting
Un saludo
Hello friends
a greeting
- Menu_Pizza_SQlite.zip
- (1.14 MiB) Downloaded 446 times
- screenshot.jpg (52.04 KiB) Viewed 4827 times
- esgici
Re: Menu_Pizza_SQlite
Gracias brothermustafa wrote: I leave a small sample that simulates control
Viva HMG
Viva INTERNATIONAL HMG
Mustafa,
Gracias y sabrosa comida !
Thank you Mustafa for nice creation
Color full creation as usual
I enjoyed Pizza
I enjoyed Pizza
Mustafa,
How to compile properly? I get multiple compile errors!
- dragancesu
Serge,
uncommnet libs=sqlite3 from \hmg.3.4.x\hmg.hbc and compile by build Menu_Sqlite.prg
Support for sqlite does not imply ?!?
Mustafa, thank you for sharing your nice project.
After reading your help file it is very clear to follow.
I am sure shadowbox() is a candidate for a UDF library.
I am happy that you have used hmg_sqlite_bridge.
Sure SQL concepts are not thrown light upon. People using DBF have to try SQL. The learning curve is very short. I have ported all my applications to SQL based, after one of my oldest project running on DBF to SQL ported last week.For me the issue would have to think Sqlite
I don't remember what happened. In the next version we will make it default. Thanks for reporting.Support for sqlite does not imply ?!?
Hola Sergeserge_girard wrote:Mustafa,
Yo añadi la siguiente linea al HMG.hbc
libs=hmgsqlite
Hi Serge
I add the following line to HMG.hbc
libs = hmgsqlite
