Grid2HTML
Grid2HTML
Dear HMG Friends,
I wanted to export grid data to a simple HTML Report that can be attached to an email. Here is a small utility to do that.
HTML Gurus, please give your comments and suggestions.
I am in the process of adding SVG elements to draw charts inside native html which enables to see our reports in browsers.
This is the syntax to call this.
 _grid2html( 'grid_2', 'form_1', 'report.html', { 'Report Header 1', 'Report Header 2', 'Report Header 3' } )
Grid2HTML.zip
(4.12 KiB) Downloaded 321 times
Re: Grid2HTML
Post by EduardoLuis »
Thanks Rathi:
Nice and usefull sample.-
With regards.
Eduardo
Steed
Re: Grid2HTML
Post by Steed »
thanks
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Grid2HTML
Post by dragancesu »
Nice
If you're looking for suggestions here they are
For the column header is used <TH> tag
CSS is a good solution, but it's better to be out HTML file (for more experienced)
if the planned print report then and it can be defined in css
Dragan
Re: Grid2HTML
Thank you Dragan. I am now learning CSS & HTML. I wanted to have the report in a single file. That's why I have included in the same file. I will try to separate CSS out.
Re: Grid2HTML
Nice contribution
Re: Grid2HTML
Thanks Rathi !
quartz565
Re: Grid2HTML
Post by quartz565 »
Thank you Rathi !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
