Download file from WWW
Success!!!
Two days of searching ant testing and I've compiled from everything I found, small function that is really BIG!
I wanna share it with us, maybe it will be useful for somebody!
I 've prepared working example with this function. Test and have fun!
PROCEDURE DownloadFromWWW
   param cURL, cLocalFileName
   LOCAL oCon, oUrl, i
   cLocalFileName := alltrim(cLocalFileName)
   oUrl := tURL():New( cUrl )
   IF Empty( oUrl )
      MsgBox("Invalid url " + cUrl)
      return
   IF oUrl:cProto != "http"
      MsgBox('This is a header test for http. Use an http address.')
      return
   END
   oCon := TipClientHttp():New( oUrl )
   oCon:nConnTimeout := 20000
   MsgBox("Connecting with "+ oUrl:cServer)
   IF oCon:Open( cUrl )
   MsgBox("Connection eshtablished." +chr(10)+"Press OK to retrieve" + oUrl:cPath +oUrl:cFile)
   oCon:WriteAll(cLocalFileName)
   MsgBox("Downloaded...")
    oCon:Close()
      MsgBox("Can't connect with "+ oUrl:cServer)
      IF oCon:SocketCon == NIL
         MsgBox("Connection not initiated")
      ELSEIF hb_InetErrorCode( oCon:SocketCon ) == 0
         MsgBox("Server sayed: "+ oCon:cReply)
         MsgBox("Error in connection: " + hb_InetErrorDesc( oCon:SocketCon ))
   END
download.zip
(2.26 KiB) Downloaded 674 times
Vanguarda
Re: Download file from WWW
Post by Vanguarda »
Hi MOL,
You are a great programmer.
I like very much. I think it is very useful for many purpose.
Thank for sharing this wonderful function with us.
with best regards,
jouhmg
Post by jouhmg »
Hi
I link that library to test this demo?
fchirico
Post by fchirico »
jouhmg wrote:Hi
I'm compiling with HMG 2.9.2 and IDE 2.8.6g and not need nothing more.
Saludos, Fernando Chirico.
program uses functions from hbtip library, which is included in HMG.
I'm working now on the function which will allow to download via proxy server.
I will share my work, when I finish.
Marek
Vanguarda
Post by Vanguarda »
mol wrote:program uses functions from hbtip library, which is included in HMG.
Marek
Great work MOL
with best regards,
I finished!
Version with downloading via proxy server is now complete!
I'm putting whole HMG example.
Please, download and test!
I will be graceful for your opinions!
PS.
Remember to add lib SOCKET in HMG preferences!
FUNCTION DownloadFromWWWviaProxy
	param cServer, cURL, cLocalFileName, cProxy, nProxyPort, cProxyUser, cProxyPassword
	private oSock, cRet
	private nPort    := 80               // 8080         //
	DEFAULT nProxyPort := 8080
	cServer := substr(cServer, at("http://",cServer) +7 )
	oSock := THttp():New()
	if !empty(cProxy)
		oSock:SetProxy( cProxy, nProxyPort, cProxyUser, cProxyPassword )
	delete file &cLocalFileName
	MsgBox("Trying tonnect to " +cServer +":" +alltrim(str( nPort )) )
	if oSock:Connect( cServer, nPort )
		MsgBox("Connected. Trying to download file")
		cAnswer := oSock:Get( cServer+cUrl)
		// remove HTTP header
		nPos := at(chr(13)+chr(10)+chr(13)+chr(10), cAnswer)
		cHeader := left(cAnswer, nPos+4)
		// we must cut off HTTP header
		cAnswer := substr(cAnswer,nPos+4)
		// search for file length
		nPos := at("Content-Length:",cHeader)
		if nPos > 0
			nLengthOfFile := val(substr(cHeader,nPos+len("Content-Length:")))
			// something wrong
			nLengthOfFile := 0
		if nLengthOfFile <> len(cAnswer)
			// something was wrong
			MsgBox("something was wrong " + cHeader)
			nFile := FCreate(cLocalFileName,0)
			FWrite(nFile, cAnswer)
			FClose(nFile)
		// Trying to close connection
		if oSock:Close()
			MsgBox("Close connection successfull")
			MsgBox("Error on close connection")
		MsgBox("Connection refused")
download_with_proxy.zip
(33.45 KiB) Downloaded 582 times
Thank you very much Marek. Just downloaded and testing. :)
Vanguarda
Post by Vanguarda »
Hi all,
Thank marek for this nice work!
regards,
APi
Post by APi »
Hello Marek,
you have a wonderful motorcycle. Thank you for your work.
Greeting from APi
