login system
dragancesu
DBs Used: DBF, MySQL, Oracle
login system
Post by dragancesu »
I tried to make a simple system to log on to the system, you just need to compile
User and password are stored in users.dbf and initially is admin / admin, when you sign up you'll be able to add, edit, delete,
There is encryption of passwords as an example, it is a function code_pass and write one of your, the example is simple, it adds 20 to characters of password
login.zip
(3.72 KiB) Downloaded 442 times
Re: login system
Dragancesu , gracias por compartir .....
Re: login system
dragancesu wrote:I tried to make a simple system to log on to the system, you just need to compile...
(When pressed escape key)
Error BASE/1066 Argument error: conditional
Called from AT_LOGIN(49)
Called from (b)LOGIN(23)
Called from _DOCONTROLEVENTPROCEDURE(5745)
Called from EVENTS(803)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5413)
Called from LOGIN(43)
Called from ON_START(74)
Called from (b)MAIN(30)
Called from _PROCESSINITPROCEDURE(5567)
Called from _ACTIVATEWINDOW(5318)
Called from MAIN(65)
Second problem : advised "user" ("admin") is lovercase and textbox property is uppercase; problem with non-english caharacters.
Re: login system
danielmaximiliano wrote:Dragancesu , gracias por compartir .....
dragancesu
Re: login system
Thanks for your comments
I tried to make a simple login system and I think I did, I saw that there is an error, the program has changed many times that I forgot to test it all again, the solution is
ON ESCAPE KEY ACTION at_login (.f.)
The most important function is code_pass that needs to hide some encryption password, the program is given as it may seem, initially placed combination admin / admin that should work, do not use UTF but I tried it with non-standard letters of the Latin alphabet and working šđžćč
in Clipper I used the C function and to
CLIPPER CODEPASS(void)
	unsigned int i, j, c, c1, c2;
	char _in[20], _out[22], c11, c22;
	strcpy( _out, "                    " );
	strcpy( _in, _parc(1) );
	j = _parclen(1);
	if (j > 10) j = 10;
	if (j < 10)
	for(i=j;i<10;i++) strcat(_in," "); j = 10;
	for(i=0;i<j;i++)
		c = _in[i]; c1 = c / 10; c2 = c - ( c1 * 10 );
		c11 = c1 + 200; c22 = c2 + 200;
		_out[i*2] = c11; _out[i*2+1] = c22;
	_retc( _out );
Re: login system
dragancesu wrote:Thanks for your comments
	j = _parclen(1);
	if (j > 10) j = 10;
	if (j < 10)
	for(i=0;i<j;i++)
	_retc( _out );
This is in HMG:
HB_FUNC ( CODEPASS )
   TCHAR _in[20], _out[22], c11, c22;
   lstrcpy ( _out, _TEXT("                    ") );
   lstrcpy ( _in, HMG_parc(1) );
   j = lstrlen ( HMG_parc(1) );
   if (j > 10) j = 10;
   if (j < 10)
   for(i=j;i<10;i++) lstrcat(_in,_TEXT(" ")); j = 10;
   for(i=0;i<j;i++)
   HMG_retc( _out );
Re: login system
Thank you Dragan and Claudio for your contribs. Would you please give us an example how to add CODEPASS ?
Re: login system
Pablo César wrote:Thank you Dragan and Claudio for your contribs. Would you please give us an example how to add CODEPASS ?
dragancesu
Re: login system
Codepass not a specific function, in Clipper is done in C in that it could not "decompile", in the harbor this is not necessary because the real C programs.
in this login system is designed code_pass function that make you want to hide the password, it can be simple or complicated, your choices
Agil Abdullah
Re: login system
Post by Agil Abdullah »
Thanks to Dragancesu & Dr.Soto for sharing.
Programmer Never Surrender
