SET BACKGROUND TASKS ON , syntax error
hynan
Post by hynan »
Hi all,
The very best wishes for this new year 2014...
I have problem with
gives syntax error
HB_IdleAdd
HB_BackGroundAdd
gives no errors.
Am trying to use someting like:
From the xHarbour Language Reference Guide.chm
// The example uses a regular background task to display the time
// once in a second while MemoEdit() is active. To ensure continuous
// display while MemoEdit() waits for user input, an idle task is
// defined which enforces background task processing.
PROCEDURE Main
LOCAL nTask, nIdle
DispOutAtSetPos( .F. )
nIdle := HB_IdleAdd( {|| HB_BackGroundRun() } )
nTask := HB_BackGroundAdd( {|| ShowTime() }, 1000 )
MemoEdit( MemoRead( "Test.prg" ), 1, 0, MaxRow()-2, MaxCOl() )
HB_BackGroundDel( nTask )
HB_IdleDel( nIdle )
PROCEDURE ShowTime()
DispoutAt( MaxRow(), MaxCol()-7, Time() )
Am i forgetting something or ?
Thanks in addvance,
Greetings...
( 3.2 (Stable) )
Re: SET BACKGROUND TASKS ON , syntax error
Hi Hynan.
SET BACKGROUND TASKS ON is not a command of HMG.
hynan
Post by hynan »
And thanks for reply,
But why is :
gives no error ?
it seems to be valid function ?
Mvg...
