Getfolder()
sunningdale
Getfolder()
Post by sunningdale »
When using Getfolder() on my system it always reverts to displaying Mycomputer and from there one has to click from folder to folder to get down to a buried sub folder.
Is there any way of using Curdir() or something else so that instead of starting from the top every time the machine remembers your last starting point and enables you to change from there.
Getfolder()
Look at this: http://hmgforum.com/viewtopic.php?p=22824#p22824 probably is what you are looking for...
sunningdale
Re: Getfolder()
THANK YOU VERY MUCH - YOU HAVE MADE SOMEONE VERY HAPPY.
Getfolder()
sunningdale wrote:THANK YOU VERY MUCH - YOU HAVE MADE SOMEONE VERY HAPPY.
:lol: Nice and probably some more...
dominique_devuyst
Re: Getfolder()
Post by dominique_devuyst »
Hello,
I have the same problem with getfolder().
Does anyone have a solution to this getfolder () that does not take into account the initpath?
I tried to compile the "getfolder sample" posted a long time ago by gfilatov (via Pablo César), but I have a 'multiple definition' linker error :
Harbour 3.2.0dev (r1601151502)
C:/hmg.3.4.3/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x0): multiple definition of `BrowseCallbackProc@16'
C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_vtu0e5.dir/example_browseforfolder.o:example_browseforfolder.c:(.text+0x230): first defined here
hbmk2[browsefolder]: Error: Running linker. 1
gcc.exe C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_vtu0e5.dir/example_browseforfolder.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_vtu0e5.dir/hbmk_vrhpuh.o C:/hmg.3.4.3/SAMPLES/Functions/GETFILE/_temp.o    -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib   -Wl,--end-group -obrowsefolder.exe  -LC:/hmg.3.4.3/harbour/lib/win/mingw -LC:/hmg.3.4.3/lib
Can someone help me with that?
Dominique
Re: Getfolder()
Hi Dominique,
Please attach the prg !
dominique_devuyst
Re: Getfolder()
Hello Serge,
Here is the 'getfolder' sample prg I tried to compile :
#include "minigui.ch"
Procedure Main()
		AT 0,0 WIDTH 200 HEIGHT 150 ;
		MAIN ;
		TITLE "GetFolder Sample" ;
		NOSIZE
		DEFINE MAIN MENU
			DEFINE POPUP 'Test'
				MENUITEM 'BrowseForFolder()' ACTION MsgInfo(BrowseForFolder('Select Folder', GetCurrentFolder()),"Result")
				MENUITEM 'Exit' ACTION Form_1.Release
			END POPUP
		END MENU
	Form_1.Center
	Form_1.Activate
Static Function BrowseForFolder( cTitle, cInitPath )
Return HMG_BrowseForFolder( NIL, cTitle, NIL, NIL, cInitPath )
* Low Level C Routines
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
#include <commdlg.h>
#include <shlobj.h>
#include <commctrl.h>
int CALLBACK BrowseCallbackProc ( HWND hWnd, UINT uMsg, LPARAM lParam, LPARAM lpData )
   TCHAR szPath[ MAX_PATH ];
   switch( uMsg )
   case BFFM_INITIALIZED:  if( lpData )
         SendMessage( hWnd, BFFM_SETSELECTION, TRUE, lpData );
      break;
   case BFFM_SELCHANGED:   SHGetPathFromIDList( ( LPITEMIDLIST ) lParam, szPath ); SendMessage( hWnd, BFFM_SETSTATUSTEXT, 0, ( LPARAM ) szPath );
   return 0;
HB_FUNC( HMG_BROWSEFORFOLDER )  // Syntax: HMG_BROWSEFORFOLDER([<hWnd>],[<cTitle>],[<nFlags>],[<nFolderType>],[<cInitPath>])
   HWND hWnd = HB_ISNIL( 1 ) ? GetActiveWindow() : ( HWND ) hb_parnl( 1 );
   BROWSEINFO BrowseInfo;
   char *lpBuffer = ( char * ) hb_xgrab( MAX_PATH + 1 );
   LPITEMIDLIST pidlBrowse;
   SHGetSpecialFolderLocation( hWnd, HB_ISNIL(4) ? CSIDL_DRIVES : hb_parni(4), &pidlBrowse );
   BrowseInfo.hwndOwner = hWnd;
   BrowseInfo.pidlRoot = pidlBrowse;
   BrowseInfo.pszDisplayName = lpBuffer;
   BrowseInfo.lpszTitle = HB_ISNIL( 2 ) ? "Select a Folder" : hb_parc( 2 );
   BrowseInfo.ulFlags = HB_ISCHAR( 5 ) ? BIF_STATUSTEXT : hb_parni( 3 );
   BrowseInfo.lpfn = HB_ISCHAR( 5 ) ? BrowseCallbackProc : NULL;
   BrowseInfo.lParam = HB_ISCHAR( 5 ) ? ( LPARAM ) ( char * ) hb_parc( 5 ) : 0;
   BrowseInfo.iImage = 0;
   pidlBrowse = SHBrowseForFolder( &BrowseInfo );
   if( pidlBrowse )
      SHGetPathFromIDList( pidlBrowse, lpBuffer );
      hb_retc( lpBuffer );
      hb_retc( "" );
   hb_xfree( lpBuffer );
#pragma ENDDUMP
Dominique
Re: Getfolder()
Hi Dominique,
This sample is a minigui sample.
You can use :
cFOLDER := GetFolder()
MSGINFO(cFOLDER)
dominique_devuyst
Re: Getfolder()
Hi Serge,
Thanks for your answer.
It's a minigui, indeed.
I saw minigui.ch in the hmg\include folder, so I thought it was possible ... I like miracles. ;)
So, my problem is :
Syntax of getfolder() is :
GetFolder ( [<cTitle>] , [<cInitPath>], [<cInvalidDataMsg>], [<lNewFolderButton>] , [<lIncludeFiles>] , [<nCSIDL_FolderType>] , [<nBIF_Flags>] )--> cSelectedFolderName
Code sample (with Img_path1 = "C:\Users\Gebruiker\Documents\Photos\") :
msginfo('Le dossier des photos actuel est : '+Img_path1)
Img_path1 := GetFolder("Dossier de l'album photos",Img_path1,"nom invalide !",.F.,.F.,,)+"\"
msginfo('Le dossier des photos est maintenant : '+Img_path1)
My problem : GetFolder does not take into account the parameter Img_path1 and always give me 'Mycomputer' as initial path in the browse for folder window.
I make a mistake ? Or maybe is a bug in getfolder? In this case is there a patch?
Anyway I am looking for a solution : another function, a patch...
Have a nice weekend,
Dominique
Re: Getfolder()
Dominique,
First check if folder "C:\Users\Gebruiker\Documents\Photos\" exists.
In my PC it is called c:\gebruikers\gebruiker\....
The sample works with c:\test
