SQLCipher ported to Harbour (Windows)
Re: SQLCipher ported to Harbour (Windows)
dhaine_adp wrote: ...The problem is when I link libsqlcipher.a and lieay32.a the application looks for libeay32.dll...
Hi Dany
As far as know, when linked a lib<xxx>. a file to an application, this application shouldn't "look" a .dll file; unless you didn't use CallDLL32() function. An "a" extension implies a "static" library, and ".dll" means "dynamic"; does I know wrong :?
dhaine_adp
Post by dhaine_adp »
Hi Esgici,
You're absolutely right and on the contrary I never made a call on libeay32.dll. I think it was called from libeay32.a which in turn used by libsqlcipher.a
There are sources from this old distribution site: http://gnuwin32.sourceforge.net/packages/openssl.htm" onclick="window.open(this.href);return false;
But these sources are big and may require time to fully rebuilt the code for used with Hb/HMG. Definitely I will not take this path as much as possible.
I would like to encrypt the SQLite3 database and in doing so I found that libsqlcipher seems to be the best way but it requires to bundle the file libeay32.dll. Now this dll file is something that I wish to eliminate. I'd prefer to have an executable file without any dll file dependency.
Another option to try is to eliminate libsqlcipher totally and independently encrypt/decrypt the file attached to ON INIT procedure and modify the HMG error handler to encrypt the file before terminating the application. However this is less secure because if the application was terminated from the TaskManager, there is no guarantee that the database is still encrypted afterwards.
Danny
Danny
Manila, Philippines
Danny :
utilize este HMG.HBC y reconstruya las librerias / Use this HMG.HBC and rebuild the libraries
# paths
incpaths=/.
incpaths=include
libpaths=lib
# main hmg libs
libs=hmg
libs=crypt
libs=edit
libs=editex
libs=graph
libs=hfcl
libs=ini
libs=report
# system libs
libs=msvfw32
libs=vfw32
# harbour contrib libs
libs=hbct
libs=hbwin
libs=hbmzip
libs=minizip
libs=hbmemio
libs=hbmisc
libs=hbmysql
libs=mysql
libs=hbtip
libs=sqlite3
libs=hbsqlit3
libs=sddodbc
libs=rddsql
libs=sddmy
libs=hbodbc
libs=odbc32
libs=hbhpdf
libs=hbfimage
libs=hbpgsql
libs=hbnetio
libs=xhb
libs=png
libs=libhpdf
libs=hbvpdf
libs=hbzebra
# ***** include this lines *****
libs=hbssl
libs=libeay32
libs=ssleay32
Libs=hbtipssl
# link compiled resources
sources=${hb_curdir}_temp.
extraiga los archivos y reemplaze / remove and replace files
LIB.rar
(900.61 KiB) Downloaded 330 times
lib in IDE.png (25.97 KiB) Viewed 5321 times
I think this is what you need
Many of us (at least myself) don't like .dll files. However, using dll files is not a bad thing as it optimizes the memory usage. For example, if you use two programs calling the same functions, RAM usage is minimized as dll files are loaded only once.
Regarding this particular situation, I have tried to create static libraries of ssl, eay32 and ssleay32 but I couldn't. So, now I distribute my software along with dll files by a setup program. This setup program would copy the dll files in windows system folder, so that other programs (if any) which need these libraries can also be benefited. And, the user doesn't know about this.
Hi Rathi :
Try this.
Download OpenSSL Win32 from http://slproweb.com/download/Win32OpenS ... 1_0_1e.exe
Download OpenSSL Win64 from http://slproweb.com/download/Win64OpenS ... 1_0_1e.exe
Install to c:\openssl
Download Harbour Contrib hbssl o use harbour sources in c:\harbour\core\contrib\hbssl
Contrib.rar
(145.4 KiB) Downloaded 335 times
Execute BuildOpenssl.bat and generate library
lib static.png (59.01 KiB) Viewed 5298 times
Thank you Daniel. I will try and tell you. :)
dhaine_adp
Hi Daniel,
Thank you very much I'll try this. Linking the libsqlcipher gives me the error below if I don't include libeay32.dll. :)
I appreciate your help.
Danny
Missing libeay32.dll
Danny
Manila, Philippines
Hi Rathinagiri :
in my settings your example SQLCipher works correctly
#define CRLF                         Chr(13)+Chr(10)
   local oDB := nil
   local cKey := 'password123'
   local cFile := 'sample.sqlite'
   local aTable := {}
   local cShow := ''
   if file( cFile )
      oDB := connect2db( 'sample.sqlite', .f. )
      if oDB == Nil
         msgstop( 'Database File can not be connected' )
         iif( miscsql( oDB, 'pragma key = ' + c2sql( cKey ) ), ;
              cShow += 'Encryption Key is set' + CRLF , msginfo( 'Encryption key can not be set' ) )
         aTable := sql( oDB, 'select name, city from master' )
         if len( aTable ) > 0
            msginfo( 'Name:' + aTable[ 1, 1 ] + ' City:' + aTable[ 1, 2 ] )
      oDB := connect2db( 'sample.sqlite', .t. )
      if oDB == Nil
         iif( miscsql( oDB, 'pragma key = ' + c2sql( cKey ) )  , ;
              cShow += 'Encryption Key is set' + CRLF , msginfo(  'Encryption key can not be set!' ) )
         iif( miscsql( oDB, 'create table master (name, city)' ) , ;
              cShow += 'Master table is created successfully!' + CRLF , msginfo( 'Table can not be created!' ) )
         iif( miscsql( oDB, 'insert into master ( name, city ) values ( ' + c2sql( 'Name1' ) + ', ' + c2sql( 'City1' ) + ' )' ) , ;
              MsgInfo( cShow + 'Sample Data updated' , 'Good Notice' ) , msginfo( 'sample data can not be updated!' ) )
Return nil
dhaine_adp
Hi Rathi,
Any progress? :) Somewhere in libsqlcipher is a call to libeay32.dll. It looks like we can't eliminate it and there is something interesting on sqlite3.c (libsqlcipher) at line no.: 4907-4918, it says:
#ifdef SQLITE_HAS_CODEC
** Specify the key for an encrypted database. This routine should be
** called right after sqlite3_open().
** The code to implement this API is not available in the public release
** of SQLite.
SQLITE_API int sqlite3_key(
sqlite3 *db, /* Database to be rekeyed */
const void *pKey, int nKey /* The key */
At this point, I am going to follow your lead, to distribute the libeay32.dll
@Daniel:
Perhaps you may have either of these files libeay32.dll or libeay64.dll or libeay.dll, into your system.
BTW my libeay32.dll is located not window system folder but from GetStartUpFolder(). During testing I'd just renaming it. I have a reason for not installing it on the system folder.
Well, I am not successful in embedding the libeay32.dll into the executable and what's left for me is to do a dirty hack out of it by combining the exe + dll file and at run-time write [fcreate()] the dll file somewhere or in the temp folder. But this method will surely irritate the Anti Virus software.
Attached is a hex view of an encrypted SQLite database.
Thanks,
Danny
This is an encrypted SQLite database
Danny
Manila, Philippines
Hi Danny,
What Hex view prg you are using ?
