HMG/HARBOUR CONSOLE APPLICATION PRINTING ON LASER PRINTER
manoj_duamzn
Post by manoj_duamzn »
Kindly help me with example code.
I makes text file with epson printer codes to print on DMP printers. Now I want to make printing for Laser Printers. What is the process. What are commands.
Kindly help me
MANOJ DUA
Re: HMG/HARBOUR CONSOLE APPLICATION PRINTING ON LASER PRINTE
Hp printers use PCL language in the same way as epson dot printers
manoj_duamzn
mol wrote:Hp printers use PCL language in the same way as epson dot printers
I try to print plain text file on Laser Printer. but it is not printing. I am using win_printFileraw(cprinter,<filename>) function for printing.
If it will print then I will try PCL codes like 027 040 115 051 066 for bold.
Please help fme how can I do this print job on Laser Printer.
Isn't it only GDI printer?
If yes, you can use my MOLPRINT project with small modification for ESC P or PCL commands recognition
manoj_duamzn
mol wrote:Isn't it only GDI printer?
Please tell me from where I can find MODPRINT project
