QHTM in HMG
QHTM in HMG
esgici wrote:My opinion is same as Daniel :arrow:
Thanks amigo Pablo;
please continue to support HMG by helping community :)
Viva HMG :D
Thank you amigo Esgici !!
QHTM in HMG
mol wrote:I've tested it, but I had problems with national fonts and CSS.
Is it possible to rsolve these problems?
These problems happen even compiling in UNICODE ? Your source editor it is in UTF-8 format ?
May you show us in captured screen your problem ?
Re: QHTM in HMG
I've tested with hmg 3.0.46 without UTF.
I didn't think about it.
I'll install new HMG and I'll test it again.
Source html was coded with UTF-8, really. My fault.
Regards, Marek
luisvasquezcl
Re: QHTM in HMG
Post by luisvasquezcl »
Gracias Pablo,
tambien me uno a Daniel y agradezco tu esfuerzo y generosidad.
Saludos cordiales,
Luis Vasquez
QHTM in HMG
luisvasquezcl wrote:Gracias Pablo,
Saludos cordiales,
Luis Vasquez
Muchas gracias Luis por el apoyo de todos ustedes.
Now Zoom and fonts handling it is possible. Thanks to our friend Claudio Soto. I releasing a new version with provisory printing option, because I am still founding much difficulties to implement QHTM function for printing.
I am with this dificulty in function PrintHTML. I am not getting print functions reconcile the Miniprint with QHTM in HMG.
The QHTM, accurate printing object handle. In MiniGUI hbprn is given by: hbprn:=hbprinter():new() and HMG no longer exists. I tried:
Static Procedure PrintHTML( cHTMLFile )
Local hContext, nCountPages, Cycle
Local hDC := _HMG_SYSDATA[374] // it is not working with this (It's what I need)
SELECT PRINTER DEFAULT ;
	ORIENTATION	PRINTER_ORIENT_PORTRAIT ;
	PAPERSIZE	PRINTER_PAPER_A4 ;
	QUALITY		PRINTER_RES_MEDIUM  ;
	PREVIEW
// SELECT PRINTER DIALOG TO lSuccess PREVIEW
hContext := QHTM_PrintCreateContext()
START PRINTDOC
If QHTM_PrintSetTextFile( hContext, cHTMLFile )
   nCountPages := QHTM_PrintLayout( hDC, hContext )
   For Cycle := 1 to nCountPages
       START PRINTPAGE
		QHTM_PrintPage( hDC, hContext, Cycle )
	   END PRINTPAGE
   Next
Endif
END PRINTDOC
QHTM_PrintDestroyContext( hContext )
But here I do not know how to get the object handle which will be necessary for:
nCountPages := QHTM_PrintLayout( HBPrn : hDC, hContext )
and
QHTM_PrintPage( HBPrn : hDC, hContext, Cycle )
As you can see, hbprinter class return a object hbprn which it can get it handle:
// Init PrintSys
// Select by dialog
hbprn:selectprinter("",.T.)
// If !Empty( HBPRNERROR )
If !Empty( hbprn:error )
   Return nIL
Endif
#define DM_ORIENTATION      0x00000001
#define DMORIENT_PORTRAIT   1
#define DM_PAPERSIZE        0x00000002
#define DMPAPER_A4          9  /* A4 210 x 297 mm  */
// Set orientation PORTRAIT
hbprn:setdevmode(DM_ORIENTATION,DMORIENT_PORTRAIT)
// Set PaperSize DMPAPER_A4
hbprn:setdevmode(DM_PAPERSIZE,DMPAPER_A4)
// Set print margins Top 2 Left 5
hbprn:setviewportorg(2,5)
// Set Preview on
hbprn:PreviewMode := .T.
// Set preview rect 0, 0, GetDesktopRealHeight(), GetDesktopRealWidth()
hbprn:previewrect:={0, 0, GetDesktopRealHeight(), GetDesktopRealWidth()}
// Set preview scale 2
hbprn:previewscale:=2
// Set thumbnails on
hbprn:Thumbnails := .T.
// Start doc name 'Print form'
hbprn:startdoc('Print form')
       // Start Page
	   hbprn:startpage()
       // End Page
	   If ( _HMG_BeginTabActive , _EndTabPage() , hbprn:endpage() )
   Next
Endif
hbprn:enddoc()
// Release PrintSys
hbprn:end()
So I tried to fix in this way but hbprinter class there is not present in HMG.
My question is how I can get the object handle in MINIPRINT or how I can replace hbprinter class ? Some colleague could help me, please ?
<Attached file removed, see last message with now release>
QHTM in HMG
With this code:
	PREVIEW
hDC := _HMG_SYSDATA[374] // it should work (this is what I need)
START PRINTDOC NAME "Print form - QHTM"
       START PRINTPAGE
	   END PRINTPAGE
   Next
Endif
END PRINTDOC
I am close. It has called Preview (two pages and it is in according with my html file) but... in blank... :cry: :x
Re: QHTM in HMG
I found something interesting in this case. If I cut off PREVIEW option, then it will print.
// PREVIEW (take out)
Would it be a bug in our PREVIEW code ?
QHTM in HMG
I GOT IT !!!
Now Preview it is working with QHTM !! Nothing wrong with our MINIPRINT !
It was a second handle needed.
I also got to change backcolor thru html commands.
Also changed font color of QHTM_MessageBox (It is like our MsgInfo).
Re: QHTM in HMG
Super Pablo.
So, that means we can format our report in html also and print in the printer. That is so cool.
I have two points to be cleared:
1. Whether html code from a variable can be printed without saving it to a html file.
2. Can we use tables and other alignment formats?
QHTM in HMG
rathinagiri wrote:Super Pablo.
:P Yeahh !!
Yes, we can print by HTML file and by context passed by variable (type character). I put more one button to show both cases.
Yes we can use tables and other formats. See Tags.doc file in package attached file.
Thank you Mr. Rathinagiri to show your entusiastic interest for it ! See QHtm\Res\HTML\qhtm.html file for more QHTM Controls.
Remarks: My first message was re-edited for better understanding.
QHtm.rar
(1.02 MiB) Downloaded 1154 times
