SQLCipher ported to Harbour (Windows)
Hazael
Re: SQLCipher ported to Harbour (Windows)
Post by Hazael »
Hello Rathinagiri,
I was looking the code of your usefull utility sql1.prg and I found something I didn't understand:
It is on the function sql():
ASize( tablearr, 0 )
Shouldn't it be:
ASize( tablearr, len(table)-1 )
Just trying to understand it...
Thanks for any help.
Hi Qatan,
It is just an initialization of the variable tablearr. Since it is a local variable, I think that line is not at all required.
Hazael
Post by Hazael »
Hello Rathinagiri,
Right. I thought it was the case but maybe I didn't understand the logic.
BTW do you have the last version of sql1.prg for sqlite only? (or could you point where to download it?)
Thanks for your help
I will upload here.
This is HMGSQL library source code for bridging SQLite/MySQL/PostgreSQL.
HMGSQL.zip
(11.93 KiB) Downloaded 371 times
Hazael
Post by Hazael »
Now I noticed it was included with HMG 3.0.44.
BTW I found this info that explains TCL is not needed to build SQLite (I do know if it would work for SQLCipher): http://www.sqlite.org/cvstrac/wiki?p=Bu ... WithoutTcl
I think it is worth of a try... what do you think?
If it works it would reduce the need for an extra tool (TCL) so it would make the whole process even simpler.
And this one: http://techtonik.rainforce.org/2005/12/ ... ndows.html seems very good too.
Thanks for all your help.
Hi Rathi!
Can you place a little working sample with SQLCipher?
Oh yes. I will do it tomorrow.
What kind of sample you want?
Exclusive for SQLite handling or SQLcipher handling?
