Cuckoo Clock
Re: Cuckoo Clock
Hi Jayadev and Alex
Thanks to you too :)
LCDN.zip
(27.69 KiB) Downloaded 383 times
sudip
Re: Cuckoo Clock
Post by sudip »
Hello Esgici,
I like it :)
I like your programming style :)
I like your simple way of coding :) (I learned many things from it, eg., I never used Context Menu. Now plan to use it seeing your code)
I like CuckooClock :)
Regards.
Re: Cuckoo Clock
Hola en especial al Maestro Esgici
Me he permitido incorporar cada 15 minutos un
Cuckoo a los 30 minutos dos Cuckoo a los 45 minutos tres
Cuckoo y a la hora cuatro Cuckoo hay que cambiar el idioma
Hello especially to Master Esgici
I have 15 minutes each incorporating a
Cuckoo two to 30 minutes to 45 minutes Cuckoo.
three and four hours Cuckoo .
We need to change the language
Greetings
Clock.zip
(96.64 KiB) Downloaded 372 times
Re: Cuckoo Clock
Thanks a lot my friend Mustafa :D
I'll try to make it multi language.
http://translate.google.com/translate wrote:Muchas gracias a mi amigo Mustafa: D
Voy a tratar de hacer múltiples idiomas.
Re: Cuckoo Clock
mustafa wrote: We need to change the language
esgici wrote: I'll try to make it multi language.
Added.
CuckoClock_Src.zip
Cucko Clock Sources
(38.39 KiB) Downloaded 359 times
Re: Cuckoo Clock
Nice work Esgici!
I've missed previous version, but this looks great.
Once I found a way to use temporary fonts without installing it (it was on this forum, but, I don't remember authoe, sorry ;) ). I think, you can use it:
#define FR_PRIVATE 0x10
#define FR_NOT_ENUM 0x20
DECLARE DLL_TYPE_INT AddFontResourceEx( DLL_TYPE_LPCTSTR lpszFileName, DLL_TYPE_DWORD fl, DLL_TYPE_LPVOID pdv) IN GDI32.DLL
function AddFont(cFontName)
local nRet := AddFontResourceEx( cFontName, FR_PRIVATE + FR_NOT_ENUM, 0 )
return NIL
I haven't test it, so you can try in free time.
More about it is on MS pages:
I've tried to add font, works OK, but I don't know how to use it...
I've tried:
frm.lbl.FontName := "LCDN"
but without effects...
Re: Cuckoo Clock
Thanks Marek :)
I can't found "temporary fonts" subject into our forum :(
May be you had seen in another place ?
If you find please inform me.
And, if you add your (and / or other ) language to context menu items in Cuckoo Clock also please inform me (only seven short string).
Re: Cuckoo Clock
It was so simple... It should be name of font, not font filename
frm.lbl.FontName := "LCDD"
Now, everything works OK :lol:
For ordering...
1. declare function if first lines of main module
2. Add font temporarily to your application:
AddFont('LCDN.TTF')
3. Set FontName property:
 FOR nDigit := 1 TO 5
            cDigit := "lblClock" + LTRIM( STR( nDigit ) )
            nlblWidth := aLMetrcs[ 1, nDigit ]
            IF nDigit < 5
               @ 5, nlblRow LABEL &cDigit HEIGHT 40 WIDTH nlblWidth FONT "LcdD" SIZE 25 CENTERALIGN  BACKCOLOR { 0, 0, 160 } FONTCOLOR WHITE  FONTNAME "LCDD"  // aColors[ nDigit ]
               @ 5, nlblRow LABEL &cDigit HEIGHT 40 WIDTH nlblWidth FONT "LcdD" SIZE 25 BACKCOLOR { 0, 0, 160 } FONTCOLOR WHITE FONTNAME "LCDD"
            nlblRow += nlblWidth
Now, youd don't need to install LCD font to your/your client system to display it on the screen.
You can also install fonts from your application, eg. at first use of app.:
		if !File(GetWindowsFolder()+"\fonts\LCDN.TTF")
			FileCopy("LCDN.TTF", GetWindowsFolder()+"\fonts\LCDN.TTF")
			RegistryWrite( "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts\LCDD" , "LCDN.TTF"  )
Below, I put translation of context menu items:
 aRVal :=  { "Kolor tła",;              // 1°
                     "Kolor zegara",;            // 2°
                     "Kolor daty",;             // 3°
                     "Dźwięk",;                  // 4°
                     "Sekundy",;                // 5°
                     "Ukryj",;                   // 6°
                     "Zakończ   ( Esc)"}
Re: Cuckoo Clock
You can also remove font:
DECLARE DLL_TYPE_BOOL RemoveFontResourceEx ( DLL_TYPE_LPCTSTR lpFileName, DLL_TYPE_DWORD fl, DLL_TYPE_LPVOID pdv ) IN GDI32.DLL
 FUNCTION RemoveFont(cFontName)
   local nRet := RemoveFontResourceEx( cFontName,FR_PRIVATE+ FR_NOT_ENUM, 0)
   RETURN Nil
I've found authors of this code:
*-- Codigo original Walter TAVERNA de San Francisco, Córdoba, Argentina. *
*-- Codigo Impresion Chelo Pcia. de Buenos Aires, Argentina. *
*-- Modificado y Adaptado Mustafa López de Alicante, Espańa 2010 *
best regards, Marek
Re: Cuckoo Clock
mol wrote: I've found authors of this code:
Thanks Marek :)
Me too, I've found the thread and then in my machine :oops:
Thanks to our friend Mustafa :)
And thanks to you again.
