SQLite
jairpinho
SQLite
Post by jairpinho »
Hola a todos, tengo problemas con SQLite para crear una lista de nombres de tablas de una base de datos utilizando inhibidores de la HMG 3.0.38 siguiendo los ejemplos, pero no puede devolver los nombres que parecen tener por favor, cualquier cosa que no se fijan en el ejemplo
FUNCTION SQLITE_TABLES()
* Uses a (special) master table where the names of all tables are stored
* Returns an array with names of tables inside of the database
LOCAL aTables := {}
Local cSelect := ""
cSelect := "SELECT name FROM sqlite_master WHERE type IN ('table','name')
AND name NOT LIKE 'sqlite_%' UNION ALL SELECT name FROM sqlite_temp_master WHERE
type IN ('table','name') ORDER BY 1;"
IF DB_IS_OPEN( Database )
aTables := SQLITE_QUERY( Database, cSelect )
msginfo( STR(Len( aTables )))
msginfo(alltrim(aTables) )
RETURN( aTables )
FUNCTION SQLITE_QUERY( Database, cSelect )
LOCAL STMT, nCCount, nI, nCType
LOCAL aRet := {}, oQuery := {}
STMT := sqlite3_prepare( Database, cSelect )
IF STMT_IS_PREPARED( STMT )
DO WHILE sqlite3_step( STMT ) == SQLITE_ROW
oQuery := {}
nCCount := sqlite3_column_count( STMT )
IF nCCount > 0
FOR nI := 1 TO nCCount
nCType := sqlite3_column_type( STMT, nI )
SWITCH nCType
CASE SQLITE_NULL
AADD( oQuery, "NULL")
EXIT
CASE SQLITE_FLOAT
CASE SQLITE_INTEGER
AADD( oQuery, LTRIM(STR( sqlite3_column_int( STMT, nI ) )) )
EXIT
CASE SQLITE_TEXT
AADD( oQuery, sqlite3_column_text( STMT, nI ) )
EXIT
END SWITCH
NEXT nI
aadd(aRet, oQuery)
ENDDO
sqlite3_finalize( STMT )
RETURN( aRet )
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: SQLite
Your code is working nice to me.
What or where do you get the problem? Also, had you seen HMGSQL\source\hmgsqlite.prg?
Is 'Database' a public variable?
jairpinho
Re: SQLite
Post by jairpinho »
I can not treat the array as a string to view or compare it with text
msginfo(alltrim(aTables) )  ----->>>> here is the problem of error
Jair Pinho
Re: SQLite
I think you can use the following code:
cList := ''
for i := 1 to len( aTables )
   cList := cList + alltrim( aTables[ i ] )
   if i < len( aTables )
      cList := cList + ', '
next i
msginfo( 'These are the tables: ' + cList )
jairpinho
Re: SQLite
Post by jairpinho »
still the same problem I can not view the array as follows
Date:08/30/11 Time: 13:12:24
Error BASE/2022 Argument error: ALLTRIM
Called from ALLTRIM(0)
Called from SQLITE_TABLES(312)
Called from PESUIQSA_DADOS(77)
Called from (b)CLIENTE(4)
Called from _PROCESSINITPROCEDURE(5088)
Called from _ACTIVATEWINDOW(4921)
Called from DOMETHOD(7374)
Called from CLIENTE(53)
Called from (b)MAIN(11)
Called from _DOCONTROLEVENTPROCEDURE(5268)
Called from EVENTS(1389)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4933)
Called from MAIN(21)
Jair Pinho
Re: SQLite
Please just change this line to:
cList := ''
   cList := cList + alltrim( aTables[ i, 1 ] )
next i
jairpinho
Re: SQLite
Post by jairpinho »
Thanks it worked Rathi
Jair Pinho
Hazael
Re: SQLite
Post by Hazael »
Thanks for sharing your code
