Harbour MiniGUI IDE 2.6.4
Posted: Tue Sep 02, 2008 1:37 pm
by Roberto Lopez
English:
- Fixed: Problems when 'Name' property value is changed in various
controls. Reported by Esgici.
Español:
- Solucionado: Problemas al cambiar la propiedad 'Name' en varios
controles. Reportado por Esgici.
Re: Harbour MiniGUI IDE 2.6.4
Posted: Sat Oct 18, 2008 5:24 pm
by rcain
Does anyone use MiniGUI IDE to create a project.
There is no sample code that really uses the a FORM created by the IDE.
Does any one have a PORJECT that is built using the IDE that:
In the code
Opens a form.
gets data from a TextBox
Looks up a record in a DBF table,
Display’s the results on the form
The project would only have to have:
2 TextBox, one for input, one for the results
1 button to perform the lookup
1 button to terminate
the DBF only needs 2 fields, a key field and a data field.
A NewBe just needs a small example that actually does something, to get started!
All examples are just snip lets, not enough to tie anything together as far as the IDE goes.
Thanks,
Robin
Posted: Sat Oct 18, 2008 6:22 pm
Hi Robin,
Welcome aboard
rcain wrote:Does anyone use MiniGUI IDE to create a project.
Personally, I am building almost all my project ( including console applications) by IDE.
Why you don't look at
HmgIDE\Samples folder ? Actually there are 21 samples and all of them are FORM based (see
.fmg files).
Does any one have a PROJECT that is built using the IDE
Please look at this tutor page :
http://vivaclipper.googlepages.com/ide_sample1_eng
Not include all of your requests, but surely respond most of your questions and may be a good starting point for you.
Happy HMG'ing
Posted: Sat Oct 18, 2008 9:18 pm
by Roberto Lopez
An IMPRESSIVE tutorial.
Thanks!!!!
Roberto.
Posted: Sun Oct 19, 2008 12:14 am
Thanks!!!!
Roberto.
All thanks about HMG are to you, Roberto.
As I denoted in
the first announce, this tutor page need
a translation aid
At least correction for this Google translated text.
Best Regards
Posted: Sun Oct 19, 2008 10:34 am
by Roberto Lopez
Thanks!!!!
Roberto.
As I denoted in
a translation aid
Best Regards
Ok. I can`t tell you when, but i'll do it.
Roberto.
Posted: Sun Oct 19, 2008 6:14 pm
by rcain
I tried to create a project on my own (see attachment), tacking full advantage of the IDE and bound fields…..(used DATA_BOUND sample program to get some insight, it does not use the IDE, I reproduced the minimum amount to see if it would works). Please look at my attachment, it fails trying to put data in the fields, I think..)
If the bound fields worked, it would be great….
Thanks,
Robin
