English:
- Fixed: Problems when 'Name' property value is changed in various
controls. Reported by Esgici.
Español:
- Solucionado: Problemas al cambiar la propiedad 'Name' en varios
controles. Reportado por Esgici.
Harbour MiniGUI IDE 2.6.4
- HMG Founder
Re: Harbour MiniGUI IDE 2.6.4
Does anyone use MiniGUI IDE to create a project.
There is no sample code that really uses the a FORM created by the IDE.
Does any one have a PORJECT that is built using the IDE that:
In the code
Opens a form.
gets data from a TextBox
Looks up a record in a DBF table,
Display’s the results on the form
The project would only have to have:
2 TextBox, one for input, one for the results
1 button to perform the lookup
1 button to terminate
the DBF only needs 2 fields, a key field and a data field.
A NewBe just needs a small example that actually does something, to get started!
All examples are just snip lets, not enough to tie anything together as far as the IDE goes.
Thanks,
Robin
In the code
Opens a form.
Thanks,
Robin
Hi Robin,
Welcome aboard
http://vivaclipper.googlepages.com/ide_sample1_eng
Not include all of your requests, but surely respond most of your questions and may be a good starting point for you.
Happy HMG'ing
Welcome aboard
Personally, I am building almost all my project ( including console applications) by IDE.rcain wrote:Does anyone use MiniGUI IDE to create a project.
Why you don't look at HmgIDE\Samples folder ? Actually there are 21 samples and all of them are FORM based (see .fmg files).There is no sample code that really uses the a FORM created by the IDE.
Please look at this tutor page :Does any one have a PROJECT that is built using the IDE
Happy HMG'ing
- HMG Founder
An IMPRESSIVE tutorial.
Thanks!!!!
All thanks about HMG are to you, Roberto.Roberto Lopez wrote:An IMPRESSIVE tutorial.
Thanks!!!!
As I denoted in the first announce, this tutor page need
a translation aid
At least correction for this Google translated text.
Best Regards
- IDE_Sample.zip
- (4 KiB) Downloaded 382 times
- HMG Founder
esgici wrote:All thanks about HMG are to you, Roberto.Roberto Lopez wrote:An IMPRESSIVE tutorial.
Thanks!!!!
a translation aid![]()
Best Regards
Ok. I can`t tell you when, but i'll do it.
I tried to create a project on my own (see attachment), tacking full advantage of the IDE and bound fields…..(used DATA_BOUND sample program to get some insight, it does not use the IDE, I reproduced the minimum amount to see if it would works). Please look at my attachment, it fails trying to put data in the fields, I think..)
If the bound fields worked, it would be great….
Thanks,
Robin
Thanks,
Robin
- MAIN.zip
- (8.6 KiB) Downloaded 377 times
