HMG 3.0 (Test I)
Posted: Sun Oct 11, 2009 5:33 am
- HMG 3.0.0 Changelog:
English:
- Updated: Harbour compiler to 2.0 Beta 3 (HMG IDE 2.9.4 and earlier
versions ARE NOT COMPATIBLE with this HMG version).
- Updated: MingW compiler to 4.4.1
- Modified: Samples.
Removed: ADORDD samples (adordd not working on
current Harbour release)
Added: RDDSQL samples.
-\HMG\SAMPLES\RDD.SQL\MYSQL
-\HMG\SAMPLES\RDD.SQL\ODBC
-\HMG\SAMPLES\RDD.SQL\ARRAY
- Modified: 'Compile.bat'. It is based on HBMK2 now, allowing incremental
builds with multiples .prg.
Usage:
Compile [options] [<script>] src[.prg]>
Options:
-d: Debugger Support
-c: Console/Mixed Mode
-i: Incremental Build
-r: Rebuild All
-incpath=<p>: additional path to search for headers
-L<libpath>: additional path to search for libraries
-l<libname>: link with <libname> library. <libname> should be without path, extension and 'lib' prefix (unless part of libname)
- <script> can be <@script> (.hbm format), <script.hbm>, <script.hbp> or <script.hbc>.
Thanks to Teo Fonrouge and Viktor Szakáts for help on this.
Samples:
* Compile one program (GUI)
Compile prog1
* Compile one program (Console/Mixed mode)
Compile -c prog1
* Compile multiple programs
Compile prog1 prog2 prog3
* Compile multiple programs (Incremental)
Compile -i prog1 prog2 prog3
* Compile multiple programs (Rebuild All)
Compile -r prog1 prog2 prog3
More Samples: \hmg\samples\multi.prg
Español:
- Actualizado: Harbour compiler a 2.0 Beta 3 (HMG-IDE versión 2.9.4 y
anteriores no es compatible con esta versión de HMG).
- Actualizado: MingW compiler a 4.4.1
- Modificado: Samples.
Eliminado: Ejemplos ADORDD (adordd no funciona en la
versión actual de Harbour)
Agregado: Ejemplos RDDSQL.
- Modificado: 'Compile.bat'. Desde esta versión, está basado en HBMK2,
permitiendo la compilación incremental de múltiples .prg.
Uso:
Compile [options] [<script>] src[.prg|.o]>
Options:
-r: Rebuild All
Ejemplos:
* Compilar un programa (GUI)
Compile prog1
* Compilar un programa (Console/Mixed mode)
Compile -c prog1
* Compilar múltiples programas
* Compilar múltiples programas (Incremental)
* Compilar multiples programas (Rebuild All)
Mas Ejemplos: \hmg\samples\multi.prg
Download/Descarga: https://sourceforge.net/projects/harbou ... e/download
Enjoy!
Roberto.
