HMG 3.0 (Test I)
HMG 3.0 (Test I)
- HMG 3.0.0 Changelog:
English:
- Updated: Harbour compiler to 2.0 Beta 3 (HMG IDE 2.9.4 and earlier
versions ARE NOT COMPATIBLE with this HMG version).
- Updated: MingW compiler to 4.4.1
- Modified: Samples.
Removed: ADORDD samples (adordd not working on
current Harbour release)
Added: RDDSQL samples.
-\HMG\SAMPLES\RDD.SQL\MYSQL
-\HMG\SAMPLES\RDD.SQL\ODBC
-\HMG\SAMPLES\RDD.SQL\ARRAY
- Modified: 'Compile.bat'. It is based on HBMK2 now, allowing incremental
builds with multiples .prg.
Usage:
Compile [options] [<script>] src[.prg]>
Options:
-d: Debugger Support
-c: Console/Mixed Mode
-i: Incremental Build
-r: Rebuild All
-incpath=<p>: additional path to search for headers
-L<libpath>: additional path to search for libraries
-l<libname>: link with <libname> library. <libname> should be without path, extension and 'lib' prefix (unless part of libname)
- <script> can be <@script> (.hbm format), <script.hbm>, <script.hbp> or <script.hbc>.
Thanks to Teo Fonrouge and Viktor Szakáts for help on this.
Samples:
* Compile one program (GUI)
Compile prog1
* Compile one program (Console/Mixed mode)
Compile -c prog1
* Compile multiple programs
Compile prog1 prog2 prog3
* Compile multiple programs (Incremental)
Compile -i prog1 prog2 prog3
* Compile multiple programs (Rebuild All)
Compile -r prog1 prog2 prog3
More Samples: \hmg\samples\multi.prg
Español:
- Actualizado: Harbour compiler a 2.0 Beta 3 (HMG-IDE versión 2.9.4 y
anteriores no es compatible con esta versión de HMG).
- Actualizado: MingW compiler a 4.4.1
- Modificado: Samples.
Eliminado: Ejemplos ADORDD (adordd no funciona en la
versión actual de Harbour)
Agregado: Ejemplos RDDSQL.
- Modificado: 'Compile.bat'. Desde esta versión, está basado en HBMK2,
permitiendo la compilación incremental de múltiples .prg.
Uso:
Compile [options] [<script>] src[.prg|.o]>
Options:
-r: Rebuild All
Ejemplos:
* Compilar un programa (GUI)
Compile prog1
* Compilar un programa (Console/Mixed mode)
Compile -c prog1
* Compilar múltiples programas
* Compilar múltiples programas (Incremental)
* Compilar multiples programas (Rebuild All)
Mas Ejemplos: \hmg\samples\multi.prg
Download/Descarga: https://sourceforge.net/projects/harbou ... e/download
Enjoy!
Vanguarda
Re: HMG 3.0 (Test I)
Post by Vanguarda »
WOW, Thank´s Master, for this new test version.
I´ll test it.
Oh! Great Roberto.
I think there are so many benefits and also hurdles. Let us tackle. :)
Vanguarda
Post by Vanguarda »
Masters, i recompile the samples include on "C:\hmg\Samples" and recompile some other projects. For me the this new version let our projects more fast. Or i´m wrong?
I could see a possible improvement in performance, with examples (and my own projects) related to the report, grid and browse control.
Please, let me know if i´m wrong.
I´ll continue test in here. Thanks again for this new version.
With Best Regards,
Wonderful ! :D
Thanks a lot Maestro
With best regards
Vanguarda wrote:Masters, i recompile the samples include on "C:\hmg\Samples" and recompile some other projects. For me the this new version let our projects more fast. Or i´m wrong?
With Best Regards,
It took me about two complete days to prepare this buid and I've had no time to do benchmarks, but I can see a possible speed inprovement too.
At least, I'm sure that compilation is faster.
rathinagiri wrote:Oh! Great Roberto.
The only serious problem that I've found is ADORDD failure.
Anyway, IMHO, RDDSQL is (by far) better soluton. It allows to work with MySql and access (mdb) databases smoothly.
On the good side is HBMK2 (invoked by 'Compile.bat' to make it easier to use).
It will be allow us to handle big projects from the command line in a simple and fast way.
Finally, new and enhanced Harbour contributions, will allow us to enhance HMG itself (hopefully) soon.
fchirico
Post by fchirico »
Enjoy!
Gracias!
La estaremos probando!
Saludos, Fernando Chirico.
Hello Master Roberto,
Thanks a lot for this version. I just downloaded it and I shall comeback after testing :)
