Page 1 of 54
I want to be a HMG Poster
Posted: Wed Aug 12, 2009 8:47 am
Hi new members,
If you want to post in HMG Forum, just reply this topic with your interest in HMG. On seeing your reply, you will be promoted as a HMG poster.
This is to avoid unnecessary spamming in the forum.
Kindly co-operate.
Thanks and regards,
S. Rathinagiri.
Re: I want to be a HMG Poster
Posted: Wed Nov 18, 2009 6:38 pm
by PedroBarna
Hi friends,
I´m from Barcelona and work with Clipper 5.2 and Visual Basic.I saw this forum
and hope a member active for this.I´m sorry for my bad english.Regards.
Pere.
Posted: Wed Nov 18, 2009 10:36 pm
by nassausky
My name is Mike and I work at a Public Library in NY. I started using dbaseIII back in 1984 and then migrated to using Clipper. I actually wrote quite a few applications that usually accesed xBase files. I even had a chance to work with a communications library to connect to the main library branch. One of the other funner projects I worked on was a simple database generator which simplified creating a GUI for creating a browsable/editable database. When the work environment changed to the Microsoft Windows environment I wound up moving away from Clipper and purchasing Clarion/Topspeed for Windows instead and did all my graphical database programming in there. Now that I tried HMG and HMG-IDE, it was nice to see how easy it was to get back into the xbase programming language.
It would be nice to join this group if you have room for me
Thanks,
M. Dietz
Posted: Wed Nov 18, 2009 11:21 pm
by martingz
Quiero postear
Posted: Thu Nov 19, 2009 2:33 pm
by Ricci
Well, this is my second try to become a member of this forum.
I´m working with the dBase language since dBase II oder III. This must be about 25 years. After dBase i used Clipper 87, Clipper 5.x.
When Windows dominates the market, i tried FiveWin (an addon for Clipper 5), dBaseWin, CA-Visual Objects and at last XBase++. VO and XBase++ a based on an object-model, so i had a lot of work with less of fun
With HMG programming is simple, you can concentrate on your progam, not on the language. That´s effective. My first program is out, it´s my first freeware and it´s successfull. I will show it in the forum if i can post.
Regards from germany ... Ricci
Posted: Thu Nov 19, 2009 5:56 pm
Welcome Ricci.
Just awaiting to see your software.
Posted: Thu Nov 19, 2009 8:52 pm
by Alex Gustow
Welcome guys!
Regards from Russia!
I'm "old but gold" boy too (I use dBase, Clipper etc. since 1987).
So welcome abord to our family
Let's play together!
Posted: Thu Dec 03, 2009 2:35 pm
by radohabjan
Hello,
my name is Rado Habjan form Slovnia and I'm a Clipper Programmer since 1990. Now after quite a lot of years I started to make programms for Windows. I have searched a few projects and then I decided for HMG. After 1 month of working I'm very satisfied with HMG and a lot of porcedures are converted from DOS Window to Windows Programm.
Best regards to All
Rado
Posted: Fri Dec 04, 2009 1:33 pm
by Itzik
My name is Itzik and I’m experience in xBase starting with Dbase3, via Quicksilver and then Clipper (87 to 5.3) from 1986.
The windows capabilities along with Clipper always interested me and I would like to join to this forum.
Itzik.
Posted: Fri Dec 11, 2009 3:56 am
Hai Rado and Itzik,
Welcome aboard. Now you can post in all the forums.
