I want to be a HMG Poster
Hi new members,
If you want to post in HMG Forum, just reply this topic with your interest in HMG. On seeing your reply, you will be promoted as a HMG poster.
This is to avoid unnecessary spamming in the forum.
Kindly co-operate.
Thanks and regards,
S. Rathinagiri.
PedroBarna
Re: I want to be a HMG Poster
Post by PedroBarna »
Hi friends,
I´m from Barcelona and work with Clipper 5.2 and Visual Basic.I saw this forum
and hope a member active for this.I´m sorry for my bad english.Regards.
Pere.
nassausky
Post by nassausky »
My name is Mike and I work at a Public Library in NY. I started using dbaseIII back in 1984 and then migrated to using Clipper. I actually wrote quite a few applications that usually accesed xBase files. I even had a chance to work with a communications library to connect to the main library branch. One of the other funner projects I worked on was a simple database generator which simplified creating a GUI for creating a browsable/editable database. When the work environment changed to the Microsoft Windows environment I wound up moving away from Clipper and purchasing Clarion/Topspeed for Windows instead and did all my graphical database programming in there. Now that I tried HMG and HMG-IDE, it was nice to see how easy it was to get back into the xbase programming language.
It would be nice to join this group if you have room for me :)
Thanks,
M. Dietz
martingz
Post by martingz »
Quiero postear
Ricci
Post by Ricci »
Well, this is my second try to become a member of this forum.
I´m working with the dBase language since dBase II oder III. This must be about 25 years. After dBase i used Clipper 87, Clipper 5.x.
When Windows dominates the market, i tried FiveWin (an addon for Clipper 5), dBaseWin, CA-Visual Objects and at last XBase++. VO and XBase++ a based on an object-model, so i had a lot of work with less of fun ;)
With HMG programming is simple, you can concentrate on your progam, not on the language. That´s effective. My first program is out, it´s my first freeware and it´s successfull. I will show it in the forum if i can post.
Regards from germany ... Ricci
Welcome Ricci.
Just awaiting to see your software.
Alex Gustow
Post by Alex Gustow »
Welcome guys!
Regards from Russia!
I'm "old but gold" boy too (I use dBase, Clipper etc. since 1987).
So welcome abord to our family :)
Let's play together!
radohabjan
Post by radohabjan »
Hello,
my name is Rado Habjan form Slovnia and I'm a Clipper Programmer since 1990. Now after quite a lot of years I started to make programms for Windows. I have searched a few projects and then I decided for HMG. After 1 month of working I'm very satisfied with HMG and a lot of porcedures are converted from DOS Window to Windows Programm.
Best regards to All
Rado
Itzik
Post by Itzik »
My name is Itzik and I’m experience in xBase starting with Dbase3, via Quicksilver and then Clipper (87 to 5.3) from 1986.
The windows capabilities along with Clipper always interested me and I would like to join to this forum.
Itzik.
Hai Rado and Itzik,
Welcome aboard. Now you can post in all the forums.
