Page 1 of 3
CURL for HMG latest Version ?
Posted: Tue Aug 16, 2022 1:29 am
by AUGE_OHR
where can i get "lates" LIB "a" for HMG :?:
"new" Sample include EMAIL.PRG but when try to run i get
hbmk2: Error: Referenced, missing, but unknown function(s):
HB_CURL_MAIL_ADDRESS_TO_EMAIL(), CURL_GLOBAL_SSLSET(), HB_CURL_DATE(),
TIP_MAILASSEMBLE()
Re: CURL for HMG latest Version ?
Posted: Wed Aug 17, 2022 1:10 am
AUGE_OHR wrote: Tue Aug 16, 2022 1:29 am hi,
TIP_MAILASSEMBLE()
donde se encuentra ese ejemplo ?
Posted: Wed Aug 17, 2022 1:57 am
by AUGE_OHR
danielmaximiliano wrote: Wed Aug 17, 2022 1:10 am donde se encuentra ese ejemplo ?
/* Copyright 2014-2017 Viktor Szakats */
#require "hbcurl"
#require "hbtip"
#include "simpleio.ch"
#include "hbcurl.ch"
#define HB_CURLVERINFO_VERSION                1
#define HB_CURLVERINFO_VERSION_NUM            2
#define HB_CURLVERINFO_PROTOCOLS              8  /* Array */
#define HB_CURLSSLBACKEND_SCHANNEL            8
#define HB_CURLSSLSET_OK                      0
#define HB_CURLOPT_MIMEPOST                   250
PROCEDURE Main( cFrom, cPassword, cTo, cHost )
   LOCAL lSystemCA, cCA := hb_PathJoin( iif( hb_DirBase() == "", hb_cwd(), hb_DirBase() ), "cacert.pem" )
   #if defined( __PLATFORM__WINDOWS )
   LOCAL tmp
   #endif
   LOCAL curl
   LOCAL lAPI_curl := curl_version_info()[ HB_CURLVERINFO_VERSION_NUM ] >= 0x073800
   LOCAL cUser
   LOCAL cText
   LOCAL cHTML
   LOCAL cSubject
   /* Require STARTTLS on port 587 (true) or allow it to proceed without it (false) */
   LOCAL lSTARTTLS_force
   IF hb_AScan( curl_version_info()[ HB_CURLVERINFO_PROTOCOLS ], "smtps",,, .T. ) == 0
      ? "Error: Requires libcurl 7.20.0 or newer, built with TLS/SSL and SMTP protocol support"
   hb_default( @cFrom    , "from@example.net" )
   hb_default( @cPassword, "password" )
   hb_default( @cTo      , "to@example.org" )
   hb_default( @cHost    , "localhost" )
   cFrom := "<" + ( cUser := hb_curl_mail_address_to_email( cFrom ) ) + ">"
   cTo := "<" + hb_curl_mail_address_to_email( cTo ) + ">"
   cHost := Lower( cHost )
   cSubject := "Example sending a MIME-formatted message"
   cText := ;
      e"This is the inline text message of the email.\r\n" + ;
      e"\r\n" + ;
      e"  It could be a lot of lines that would be displayed in an email\r\n" + ;
      e"viewer that is not able to handle HTML.\r\n"
   cHTML := ;
      e"<html><body>\r\n" + ;
      e"<p>This is the inline <strong>HTML</strong> message of the email.</p>" + ;
      e"<br>\r\n" + ;
      e"<p>It could be a lot of HTML data that would be displayed by " + ;
      e"email viewers able to handle HTML.</p>" + ;
      e"</body></html>\r\n"
   lSTARTTLS_force := .F.
   /* NOTE: Consult your provider for updated settings
            and create a Pull Request if necessary. */
   DO CASE
   CASE cHost == "apple" .OR. "@icloud.com" $ cFrom .OR. "@mac.com" $ cFrom .OR. "@me.com" $ cFrom
      cHost := "smtp://smtp.mail.me.com:587"; lSTARTTLS_force := .T.
   CASE cHost == "fastmail" .OR. "@fastmail.com" $ cFrom .OR. "@fastmail.fm" $ cFrom
      cHost := "smtps://smtp.fastmail.com"
   CASE cHost == "gmx.net" .OR. "@gmx.net" $ cFrom .OR. "@gmx.ch" $ cFrom .OR. "@gmx.de" $ cFrom
      cHost := "smtps://mail.gmx.net"
   CASE cHost == "google" .OR. "@gmail.com" $ cFrom .OR. "@googlemail.com" $ cFrom
      cHost := "smtps://smtp.gmail.com"
   CASE cHost == "mail.ru" .OR. "@mail.ru" $ cFrom
      cHost := "smtps://smtp.mail.ru"
   CASE cHost == "netease" .OR. "@163.com" $ cFrom
      cHost := "smtps://smtp.163.com"
   CASE cHost == "office365"
      cHost := "smtp://smtp.office365.com:587"; lSTARTTLS_force := .T.
   CASE cHost == "outlook" .OR. "@outlook.com" $ cFrom .OR. "@hotmail.com" $ cFrom
      cHost := "smtp://smtp-mail.outlook.com:587"; lSTARTTLS_force := .T.
   CASE cHost == "sina" .OR. "@sina.com" $ cFrom
      cHost := "smtps://smtp.vip.sina.com"
   CASE cHost == "uol" .OR. "@uol.com.br" $ cFrom
      cHost := "smtps://smtps.uol.com.br"
   CASE cHost == "yahoo" .OR. "@yahoo.com" $ cFrom
      cHost := "smtps://smtp.mail.yahoo.com"
   CASE cHost == "mailtrap.io" .OR. "@mailtrap.io" $ cFrom
      cHost := "smtp://smtp.mailtrap.io:465"; lSTARTTLS_force := .T.
      cUser := StrTran( cUser, "@mailtrap.io" )
   CASE cHost == "localhost"
      cHost := "smtp://localhost:1025"  /* MailHog */
      cUser := cPassword := NIL
   CASE cHost == "securesmtp.t-online.de"
      cHost := "smtp://securesmtp.t-online.de:465"; lSTARTTLS_force := .T.
   CASE cHost == "smtp.web.de"
      cHost := "smtp://smtp.web.de:587"; lSTARTTLS_force := .T.
   ENDCASE
   ? "libcurl:", curl_version_info()[ HB_CURLVERINFO_VERSION ]
   ? "Payload API:", iif( lAPI_curl, "libcurl native", "tip_MailAssemble()" )
   ? "Host:", cHost, iif( lSTARTTLS_force, "(must STARTTLS)", "" )
   #if defined( __PLATFORM__UNIX )
      lSystemCA := .T.
   #elif defined( __PLATFORM__WINDOWS )
      /* Switch to SChannel SSL backend, if available (on Windows).
         Doing this to use the OS certificate store. */
      curl_global_sslset( -1,, @tmp )
      IF ( lSystemCA := ;
         HB_CURLSSLBACKEND_SCHANNEL $ tmp .AND. ;
         curl_global_sslset( HB_CURLSSLBACKEND_SCHANNEL ) == HB_CURLSSLSET_OK )
         cCA := NIL
         cCA := hb_DirBase() + hb_DirSepToOS( "../../../bin/" ) + cCA
   #else
      lSystemCA := .F.
   #endif
   curl_global_init()
   IF Empty( curl := curl_easy_init() )
      ? "Failed to init"
      IF ! lSystemCA
         IF hb_vfExists( cCA )
            curl_easy_setopt( curl, HB_CURLOPT_CAINFO, cCA )
            ? "Error: Trusted Root Certificates missing. Open this URL in your web browser:"
            ? "  " + "https://curl.se/ca/cacert.pem"
            ? "and save the file as:"
            ? "  " + cCA
      curl_easy_setopt( curl, HB_CURLOPT_USE_SSL, ;
         iif( lSTARTTLS_force, HB_CURLUSESSL_ALL, HB_CURLUSESSL_TRY ) )
      curl_easy_setopt( curl, HB_CURLOPT_UPLOAD )
      curl_easy_setopt( curl, HB_CURLOPT_URL, cHost )
      curl_easy_setopt( curl, HB_CURLOPT_PROTOCOLS, ;
         hb_bitOr( HB_CURLPROTO_SMTPS, HB_CURLPROTO_SMTP ) )
      curl_easy_setopt( curl, HB_CURLOPT_TIMEOUT_MS, 15000 )
      curl_easy_setopt( curl, HB_CURLOPT_VERBOSE, .T. )
      curl_easy_setopt( curl, HB_CURLOPT_USERNAME, cUser )
      curl_easy_setopt( curl, HB_CURLOPT_PASSWORD, cPassword )
      curl_easy_setopt( curl, HB_CURLOPT_MAIL_FROM, cFrom )
      curl_easy_setopt( curl, HB_CURLOPT_MAIL_RCPT, { cTo } )
      IF lAPI_curl
         curl_easy_setopt( curl, HB_CURLOPT_HTTPHEADER, { ;
            "Date: " + hb_curl_date(), ;
            "To: " + cTo, ;
            "From: hbcurl " + cFrom, ;
            "Cc: " + cTo, ;
            "Message-ID: <dcd7cb36-11db-487a-9f3a-e652a9458efd@rfcpedant.example.org>", ;
            "Reply-To: " + cFrom, ;
            "Disposition-Notification-To: " + cFrom, ;
            "X-Priority: " + hb_ntos( 3 ), ;  /* 1: high, 3: standard, 5: low */
            "Subject: " + cSubject } )
         /* NOTE: 'charset' to be added when implemented */
         curl_easy_setopt( curl, HB_CURLOPT_MIMEPOST, { ;
            { "subparts" => { ;
              { "data" => cHTML, ;
                "type" => "text/html" }, ;
              { "data" => cText } }, ;
              "type" => "multipart/alternative", ;
              "headers" => { "Content-Disposition: inline" } }, ;
            { "filedata" => __FILE__ }, ;
            { "data" => Replicate( hb_BChar( 123 ), 1024 ), ;
              "type" => "image/png", ;
              "encoder" => "base64", ;  /* binary, 8bit, 7bit, base64, quoted-printable */
              "filename" => "mock.png" } } )
         cText := tip_MailAssemble( ;
            "hbtip " + cFrom, ;
            { cTo }, ;
            /* aCC */, ;
            cText, ;
            cSubject, ;
            { __FILE__, { "mock.png", Replicate( hb_BChar( 123 ), 1024 ) } } /* attachments */, ;
            /* nPriority */, ;
            /* lRead */, ;
            /* cReplyTo */, ;
            /* cCharset */, ;
            /* cEncoding */, ;
            .F. /* lBodyHTML */, ;
            /* bSMIME */ )
         curl_easy_setopt( curl, HB_CURLOPT_UL_BUFF_SETUP, cText )
         curl_easy_setopt( curl, HB_CURLOPT_INFILESIZE_LARGE, hb_BLen( cText ) )
      ? "Result:", curl_easy_perform( curl )
WAIT
      curl_easy_cleanup( curl )
FUNCTION hb_curl_mail_address_to_email( cAddress )
   LOCAL tmp, tmp1
   IF ( tmp := At( "<", cAddress ) ) > 0 .AND. ;
      ( tmp1 := hb_At( ">", cAddress, tmp + 1 ) ) > 0
      RETURN AllTrim( SubStr( cAddress, tmp + 1, tmp1 - tmp - 1 ) )
   RETURN cAddress
FUNCTION hb_curl_mail_address_to_name( cAddress )
   LOCAL tmp
      hb_At( ">", cAddress, tmp + 1 ) > 0
      RETURN RTrim( Left( cAddress, tmp - 1 ) )
RETURN cAddress
the Sample is from hb-main.zip made by Viktor Szakats
i have have found it "somewhere" @GitHub ...
it include Source
date.c
easy.c
escold.c
global.c
miscc.c
ver.c
hbcurl.ch
hbcurl.hbc
hbcurl.hbp
hbcurl.hbx
misc.prg
tests\email.prg
tests\ftp_uldl.prg
tests\hbmk.hbm
so how to build LIB "a" from Source :idea:
p.s. "where" to put Source to build :?:
Posted: Wed Aug 17, 2022 2:53 am
by AUGE_OHR
have try Code using Extended Version
Turbo Incremental Link 5.69 Copyright (c) 1997-2005 Borland
Error: Unresolved external '_HB_FUN_CURL_VERSION_INFO' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_CURL_GLOBAL_SSLSET' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_CURL_GLOBAL_INIT' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_CURL_EASY_INIT' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_CURL_EASY_SETOPT' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_HB_CURL_DATE' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_CURL_EASY_PERFORM' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
Error: Unresolved external '_HB_FUN_CURL_EASY_CLEANUP' referenced from G:\MINIGUI\SAMPLES\APPLICATIONS\SENDMAIL2\EMAIL.OBJ
so it seem a older hbCURL Version than HMG 3.4.4 while more HB_FUNC() are missing
Posted: Sun Aug 21, 2022 12:53 am
If you have the entire source code, you can try the batch file which comes along with HMGSQL.
AUGE_OHR wrote: Wed Aug 17, 2022 1:57 am
#require "hbcurl"
#require "hbtip"
   LOCAL tmp
   #endif
   LOCAL curl
   LOCAL cUser
   LOCAL cText
   LOCAL cHTML
   LOCAL cSubject
   cText := ;
      e"\r\n" + ;
   cHTML := ;
      e"<br>\r\n" + ;
   DO CASE
   ENDCASE
      lSystemCA := .T.
      IF ( lSystemCA := ;
         cCA := NIL
   #else
      lSystemCA := .F.
   #endif
   curl_global_init()
      ? "Failed to init"
      IF ! lSystemCA
            ? "  " + cCA
      IF lAPI_curl
            "To: " + cTo, ;
            "Cc: " + cTo, ;
            { "subparts" => { ;
            "hbtip " + cFrom, ;
            { cTo }, ;
            /* aCC */, ;
            cText, ;
            cSubject, ;
            /* nPriority */, ;
            /* lRead */, ;
            /* cReplyTo */, ;
            /* cCharset */, ;
            /* cEncoding */, ;
            /* bSMIME */ )
WAIT
   LOCAL tmp, tmp1
   RETURN cAddress
   LOCAL tmp
RETURN cAddress
it include Source
date.c
easy.c
escold.c
global.c
miscc.c
ver.c
hbcurl.ch
hbcurl.hbc
hbcurl.hbp
hbcurl.hbx
misc.prg
tests\email.prg
tests\ftp_uldl.prg
tests\hbmk.hbm
Posted: Mon Aug 22, 2022 4:07 am
by AUGE_OHR
hi Rathinagiri,
this is the LIB Source for that Email Sample.
hbcurl.zip
(38.21 KiB) Downloaded 805 times
Question :
a.) "where" to put those Source :?:
b.) "how" to use hbcurl.hbp :?:
i guess to put Source into x:\hmg.3.4.4\HARBOUR\contrib\hbcurl\
and start with : hbmk2 hbcurl.hbp
Posted: Thu Aug 25, 2022 11:18 am
Create Build.bat using the below code inside HMG Source folder say d:\hmg.3.5\source\hbcurl
@echo off
SET HMGPATH=%~dp0%
SET HMGPATH1=%HMGPATH:~0,-15%
SET PATH=%HMGPATH1%\harbour\bin;%HMGPATH1%\mingw\bin;%PATH%
hbmk2 hbcurl.hbp -i%hmgpath1%\include
pause
When I tried to run the build.bat it says "Missing Dependency Curl"
Posted: Thu Sep 22, 2022 12:03 pm
by edk
Support for IMAP and SMTP protocols from HMG using the latest fork of the libcurl library.
In the attachment I am sending sources, libraries for example of using libCurl in communication with mail servers via IMAP and SMTP protocols.
The program was tested on several IMAP servers: web.de; gmail.com; om.pl; onet.pl using both SSL and STARTTLS - however, I can not guarantee that it will work properly on all servers, I worked a bit in the dark, mostly by trial and error, because IMAP documents are quite extensive, I focused on the basic activities: logging, listing, reading messages, sending messages, deleting messages, creating and deleting folders, and placing messages after sending to the 'Sent' folder.
Attached is a ready configuration for connecting to the IMAP web.de server, but you can try to connect to your server by simply selecting the Configure button.
Important. The newest libraries for both libcurl and the Harbour fork of this library are required for the program to compile.
The libcurl.dll (version 7.85) and the rest of the .dll files should be placed in the same folder as the executing program. The libCurl fork for Harbour is located in the hmg.3.4.4 subfolder. You need to copy the contents of this folder to your location of hmg.3.4.4 (not tested on other versions) overwriting old files.
The new fork is necessary to be able to read the information headers sent from the IMAP server. Unfortunately, the native functions for reading these headers do not work in this fork, the solution is to process them in debug mode, which slows down the whole process, but well: Beggars can't be choosers ;-)
Note, use this tool with caution as folders and messages can be deleted.
IMAP folder names are encoded in mUTF-7 (modified UTF-7), so there is support for this encoding in the source.
I noticed that TipMail doesn't always work properly with all message formats, but I haven't found a newer version on the web, so we have to deal with its limitations. Also, ActiveX shell.explorer.2 support from a thread other than the main thread causes the program to crash, so I resigned from a separate thread for reading messages and download them in the main one.
PS. A big thank you to Marek (MOL) for the effort he put into paving the way for success.
Some comments and functions may be in Polish, which I'm sorry for, but I didn't have much time to clean up the code. I hope the code will be quite understandable after all.
edk.
Posted: Thu Sep 22, 2022 1:36 pm
by mol
Great work, Edward!
I only began and you're great finishman!
Posted: Thu Sep 22, 2022 7:10 pm
Thanks Edward !
Great job!
