read binary file with fopen
Posted: Sun Sep 10, 2017 3:11 am
by jairpinho
read binary file with fopen, already performed tests and does not work follow binary file
20161228.zip
file *.dtl
(3.39 KiB) Downloaded 380 times
Re: read binary file with fopen
Posted: Sun Sep 10, 2017 12:22 pm
by KDJ
jairpinho
This file can be read without any problem:
#include "Fileio.ch"
FUNCTION Main()
  LOCAL cFile   := "20161228.dtl"
  LOCAL nHandle := fOpen(cFile, FO_READ + FO_COMPAT)
  LOCAL nLen
  LOCAL cContent
  IF nHandle < 0
    MsgBox("Error opening file!")
    fSeek(nHandle, 0, FS_SET)
    nLen := HB_fSize(cFile)
    //read all content of file
    cContent := HB_fReadLen(nHandle, nLen)
    MsgBox(Len(cContent))
    //read 20 last bytes
    fSeek(nHandle, -20, FS_END)
    fClose(nHandle)
Posted: Sun Sep 10, 2017 6:49 pm
by jairpinho
KDJ wrote: Sun Sep 10, 2017 12:22 pm jairpinho
FUNCTION Main()
  LOCAL nLen
  LOCAL cContent
  IF nHandle < 0
    fClose(nHandle)
Hello KDJ you are reading the file size this is not an error, it will only give an error when trying to read the contents of the file that would be what I need to follow, an example of what is inside the file, I need to import this into a grid
dados arquivo.gif (59.48 KiB) Viewed 5939 times
Posted: Mon Sep 11, 2017 7:29 am
Jair,
IMO: better take a EDITBOX to display content.
For a GRID you will need to create several lines (say 80char), divide cContent in chuncks of 80chars and put them in a GRID.
Posted: Mon Sep 11, 2017 2:09 pm
by BeGeS
Serge,
This is a .DTL file.
I'm afraid that with EDITBOX you will not get anything, neither with FREADSTR() or similar low-level functions.
It would be necessary a tool that would make the contents of the file something readable.
Posted: Mon Sep 11, 2017 3:37 pm
Absolutely right !
Browsing works with Free Hex Editor Neo.
Posted: Sat Jan 06, 2018 2:32 am
by jairpinho
Hello, I found the dtl files are data files, I'm trying to connect via odbs but without success, so I found the lib site need help to convert the mak file
http://dtemplatelib.sourceforge.net/index.htm
DTLbcb5.zip
(1.27 KiB) Downloaded 321 times
