To build prg and folders with spaces by IDE
Posted: Thu Nov 03, 2016 1:59 pm
Hi Claudio,
Do you remember this message ?
Recently I make a demo for CheckBox text to be aligned to the left and I've created a folder in my repository place with folder name:
C:\My Sources\HMG\CheckBox Text on the Left
Please note this folder contains space in its name. Which make easy to find later.
I make a Compile.bat file for building. The main batch file in C:\hmg.3.4.3 works properly, nicely according my old request (in this other topic).
But in our HMG/IDE, this doesn't work...
At the time it's coming this message error:
Then I've checked what IDE it's passing as parameters and I saw the fullpath and project was not quoted...
Is it possible to make our IDE in the next release to insert quotes in it ?
If you do this, all projects even with espaces in its names will be posible for building by IDE also.
When the IDE be corrected (in case), it would pass parameter like this:
These suggestions are TOTALLY backward compatible with any project.
I've attached this project folder for your appreciation and tests.
