hbmk2 -cpu option
Posted: Sun Jan 17, 2016 4:42 pm
Those of you following Viktor's fork of Harbour would note that now hbmk2 -cpu=x64 produces a 64bit application directly on the same code.
https://github.com/vszakats/harbour-cor ... /v3.4.0dev
I have tried with Harbour hbmk2 -cpu=x86_64, it now produces 32bit app. I have notified the same in Harbour-user forum requesting if similar command would directly produce a 64bit application.
MY REQUEST IS IF THE DEVELOPERS AT HMG CAN ALSO INTRODUCE A SIMILAR Option since we are also using hbmk2 with options. IT WOULD THEN BE SO EASY TO MIGRATE 32 BIT APPS TO 64 BITS.
Warm regards,
Jayadev
Warm regards,
Jayadev
