Function with Unknown number of parameters - Possible?
Posted: Sun Jun 07, 2015 12:14 pm
Is it possible in Harbour to have a function defined with unknown number of parameters?
For example, I want to define like this:
Function MyFunction( Parameter1, Parameter2, Parameter3,..,ParameterN)
nParameters := pcount()
?nParamters
return nil
Re: Function with Unknown number of parameters - Possible?
Posted: Sun Jun 07, 2015 1:31 pm
by Carlos Britos
Hi
maybe this is what you want:
PROCEDURE TEST_1_3v( a, b, c, ... )
   LOCAL i := "i"
   ?? ProcName( 0 ), " received: ", PCount()
   ? "i=", i
   ? "a=", a
   ? "b=", b
   ? "c=", c
   FOR i := 1 TO PCount()
      ? i, "=", hb_PValue( i )
   FOR EACH i IN hb_AParams()
      ? i:__enumindex, "-", i
   Inkey( 0 )
samples in \harbour\tests\varparam.prg
Posted: Sun Jun 07, 2015 2:14 pm
Going a little bit deeper...
Trying with this:
Function Main(...)
Local aArg := hb_aParams()
Local aPar := ScanParam(aArg)
If aPar[1]="F"
   SetDisplayFullScreen(1)
If aPar[2]="P"
   cPrinter:="LPT1"
Function ScanParam(aArg)
Local aRet:={"",""}, nLen:=HMG_Len(aArg), i
For i=1 To nLen
    If hb_USubStr(aArg[i],1,1)="/"
       If hb_USubStr(HMG_Upper(aArg[i]),2,1)="F"
	      aRet[1]:="F"
       ElseIf hb_USubStr(HMG_Upper(aArg[i]),2,1)="W"
	      aRet[1]:="W"
	   Else
		  aRet[1]:="N"
       Endif
	Else
       aRet[2]:=aArg[i]
    Endif
Next
Return aRet
This example of parameters, let you process all parameters and also identify it. Because sometimes users do not follows the strict sequency.
The big point is "..." after parenthesis at Main function to receive all parameters.
I hope be useful. :D
Posted: Sun Jun 07, 2015 4:00 pm
Rathinagiri wrote:Is it possible in Harbour to have a function defined with unknown number of parameters?
Please look at here SEH2.zip\SEHandlr.Prg\PROCEDURE KKOUT() ( Line : 113 )
Posted: Sun Jun 07, 2015 4:24 pm
Wow! That is so great about this language. :)
Thank you friends for your immediate and timely help.
Posted: Tue Jun 09, 2015 2:29 am
by dhaine_adp
Simply nice, Pablo, Carlos and Esgici. :)
Posted: Tue Jun 09, 2015 10:30 am
by quartz565
Thank you all !!
