Function with Unknown number of parameters - Possible?
Is it possible in Harbour to have a function defined with unknown number of parameters?
For example, I want to define like this:
Function MyFunction( Parameter1, Parameter2, Parameter3,..,ParameterN)
nParameters := pcount()
?nParamters
return nil
Carlos Britos
Re: Function with Unknown number of parameters - Possible?
Post by Carlos Britos »
Hi
maybe this is what you want:
PROCEDURE TEST_1_3v( a, b, c, ... )
   LOCAL i := "i"
   ?? ProcName( 0 ), " received: ", PCount()
   ? "i=", i
   ? "a=", a
   ? "b=", b
   ? "c=", c
   FOR i := 1 TO PCount()
      ? i, "=", hb_PValue( i )
   FOR EACH i IN hb_AParams()
      ? i:__enumindex, "-", i
   Inkey( 0 )
samples in \harbour\tests\varparam.prg
Going a little bit deeper...
Trying with this:
Function Main(...)
Local aArg := hb_aParams()
Local aPar := ScanParam(aArg)
If aPar[1]="F"
   SetDisplayFullScreen(1)
If aPar[2]="P"
   cPrinter:="LPT1"
Function ScanParam(aArg)
Local aRet:={"",""}, nLen:=HMG_Len(aArg), i
For i=1 To nLen
    If hb_USubStr(aArg[i],1,1)="/"
       If hb_USubStr(HMG_Upper(aArg[i]),2,1)="F"
	      aRet[1]:="F"
       ElseIf hb_USubStr(HMG_Upper(aArg[i]),2,1)="W"
	      aRet[1]:="W"
	   Else
		  aRet[1]:="N"
       Endif
	Else
       aRet[2]:=aArg[i]
    Endif
Next
Return aRet
This example of parameters, let you process all parameters and also identify it. Because sometimes users do not follows the strict sequency.
The big point is "..." after parenthesis at Main function to receive all parameters.
I hope be useful. :D
Rathinagiri wrote:Is it possible in Harbour to have a function defined with unknown number of parameters?
Please look at here SEH2.zip\SEHandlr.Prg\PROCEDURE KKOUT() ( Line : 113 )
Wow! That is so great about this language. :)
Thank you friends for your immediate and timely help.
dhaine_adp
Post by dhaine_adp »
Simply nice, Pablo, Carlos and Esgici. :)
Danny
Manila, Philippines
quartz565
Post by quartz565 »
Thank you all !!
Nikos.
os: Windows Server 2019 - 64
