#include once "windows.bi"
declare function WinMain ( byval hInstance as HINSTANCE, _
byval hPrevInstance as HINSTANCE, _
byval szCmdLine as string, _
byval iCmdShow as integer ) as integer
end WinMain( GetModuleHandle( null ), null, Command( ), SW_NORMAL )
function WndProc ( byval hWnd as HWND, _
byval wMsg as UINT, _
byval wParam as WPARAM, _
byval lParam as LPARAM ) as LRESULT
function = 0
select case( wMsg )
CASE WM_HOTKEY
MessageBox( null, "Hotkey is press", "Hotkey!!!", MB_ICONINFORMATION )
case WM_CREATE
exit function
case WM_PAINT
dim rct as RECT
dim pnt as PAINTSTRUCT
dim hDC as HDC
hDC = BeginPaint( hWnd, @pnt )
GetClientRect( hWnd, @rct )
DrawText( hDC, _
"Hello, World!", _
-1, _
@rct, _
DT_SINGLELINE or DT_CENTER or DT_VCENTER )
EndPaint( hWnd, @pnt )
exit function
case WM_KEYDOWN
if( lobyte( wParam ) = 27 ) then
PostMessage( hWnd, WM_CLOSE, 0, 0 )
end if
case WM_DESTROY
PostQuitMessage( 0 )
exit function
end select
function = DefWindowProc( hWnd, wMsg, wParam, lParam )
end function
dim wMsg as MSG
dim wcls as WNDCLASS
dim hWnd as HWND
Dim nID1 As Integer
Dim nID2 As Integer
Dim nID3 As Integer
'Dim iRet As Long
nID1 = 33000
nID2 = 33001
nID3 = 33002
function = 0
with wcls
.style = CS_HREDRAW or CS_VREDRAW
.lpfnWndProc = @WndProc
.cbClsExtra = 0
.cbWndExtra = 0
.hInstance = hInstance
.hIcon = LoadIcon( NULL, IDI_APPLICATION )
.hCursor = LoadCursor( NULL, IDC_ARROW )
.hbrBackground = GetStockObject( WHITE_BRUSH )
.lpszMenuName = NULL
.lpszClassName = @"HelloWin"
end with
if( RegisterClass( @wcls ) = FALSE ) then
MessageBox( null, "Failed to register wcls", "Error", MB_ICONERROR )
exit function
end if
hWnd = CreateWindowEx( 0, _
@"HelloWin", _
"Press F10 to F12 to the hotkey", _
WS_OVERLAPPEDWINDOW, _
CW_USEDEFAULT, _
CW_USEDEFAULT, _
CW_USEDEFAULT, _
CW_USEDEFAULT, _
NULL, _
NULL, _
hInstance, _
NULL )
'iRet = RegisterHotKey(hWnd, nID1, 0, VK_F10)
'If iRet = 0 Then
If RegisterHotKey(hWnd, nID1, 0, VK_F10) = 0 Then
MessageBox(null, "RegisterHotKey F10 fail!!", "Fail", MB_ICONERROR)
End If
'iRet = RegisterHotKey(hWnd, nID2, 0, VK_F11)
'If iRet = 0 Then
If RegisterHotKey(hWnd, nID2, 0, VK_F11) = 0 Then
MessageBox(null, "RegisterHotKey F11 fail!!", "Fail", MB_ICONERROR)
End If
'iRet = RegisterHotKey(hWnd, nID3, 0, VK_F12)
'If iRet = 0 Then
If RegisterHotKey(hWnd, nID3, 0, VK_F12) = 0 Then
MessageBox(null, "RegisterHotKey F12 fail!!", "Fail", MB_ICONERROR)
End If
ShowWindow( hWnd, iCmdShow )
UpdateWindow( hWnd )
while( GetMessage( @wMsg, NULL, 0, 0 ) <> FALSE )
TranslateMessage( @wMsg )
DispatchMessage( @wMsg )
wend
UnregisterHotKey(hWnd, nID1)
UnregisterHotKey(hWnd, nID2)
UnregisterHotKey(hWnd, nID3)
function = wMsg.wParam
end function
