ON KEY F12 does not work in HMG 3.3.1
F1 to F11 works just fine, CONTROL+F12 does work but F12 does not work
For example (see attachment)
ON KEY F12 OF Win_1 ACTION MsgDebug('TEST F12')
- F12_bug_test.zip
- (1.29 MiB) Downloaded 316 times
May be not a bug in HMG.
I think MS Windows just not allow hotkey for F12.
http://msdn.microsoft.com/en-us/library ... s.85).aspx
The F12 key is reserved for use by the debugger at all times, so it should not be registered as a hot key. Even when you are not debugging an application, F12 is reserved in case a kernel-mode debugger or a just-in-time debugger is resident.
Re: ON KEY F12 does not work in HMG 3.3.1
Bonsoir,please don't send file in .exetrmpluym wrote:F1 to F11 works just fine, CONTROL+F12 does work but F12 does not work
Thanks
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
URL tag was added and link re-composed to tiampei message.
Please next time, use URL tags for links.
Oic,Pablo César wrote:URL tag was added and link re-composed to tiampei message.
Thank you for remind me and re-composed the post.
Also a lot of other programs make use of the F12 key. For example Microsoft Word 2010 uses F12 (save as) . When it was a Windows limitation the F12 key also would not work in other programs.
I also use xHarbour. In xHarbour i can also use the F12 in my xBase 32 bits executables.
A lot of other programs make use of the F12 key. For example Microsoft Word 2010 uses F12 (save as) . When it was a Windows limitation the F12 key also would not work in other programs.
So why not HMG ?
So why not HMG ?
I have try using 3 compilers. HMG, FreeBasic and Dev-c, all not support for hotkey F12. Or I missing something
Here I post the source I test in separated posts.
For HMG, I have bypass the standard function and direct into low API function to see the problem.
HMG code:
HMG code:
#pragma BEGINDUMP
#include <windows.h>
HB_FUNC ( INITHOTKEY )
RegisterHotKey(
(HWND) hb_parnl(1 ) , // window to receive hot-key notification
hb_parni(4) , // identifier of hot key
hb_parni(2) , // key-modifier flags
hb_parni(3) // virtual-key code
HB_FUNC ( RELEASEHOTKEY )
UnregisterHotKey(
(HWND) hb_parnl(1), // window associated with hot key
hb_parni(2) // identifier of hot key
HB_FUNC ( REGISTERHOTKEY )
int iRet =
RegisterHotKey(
(HWND) hb_parnl(1) , // window to receive hot-key notification
hb_parni(2) , // identifier of hot key
hb_parni(3) , // key-modifier flags
hb_parni(4) // virtual-key code
hb_retl(iRet); // Return boolean
#pragma ENDDUMP
PROCEDURE Main
Local hWnd, nID1, nID2, nID3
DEFINE WINDOW Win_1 AT 157 , 162 WIDTH 550 HEIGHT 350 TITLE "Press F10 and F12 function keys to test" MAIN NOMAXIMIZE NOMINIMIZE
// On Key F10 of Win_1 Action MsgInfo('Test F10')
// ON KEY F11 OF Win_1 ACTION MsgInfo('TEST F11')
// ON KEY F12 OF Win_1 ACTION MsgInfo('TEST F12')
/* nID1 := _GetId()
nID2 := _GetId()
nID3 := _GetId() */
nID1 := 320
nID2 := 321
nID3 := 322
hWnd := GetFormHandle("Win_1")
MsgInfo(hb_ValToStr(InitHotkey(hWnd, 0, VK_F10, nID1)))
MsgInfo(hb_ValToStr(InitHotkey(hWnd, 0, VK_F11, nID2)))
MsgInfo(hb_ValToStr(InitHotkey(hWnd, 0, VK_F12, nID3)))
MsgInfo("Register hotkey is: " + hb_ValToStr(RegisterHotkey(hWnd, nID1, 0, VK_F10)))
MsgInfo("Register hotkey is: " + hb_ValToStr(RegisterHotkey(hWnd, nID2, 0, VK_F11)))
MsgInfo("Register hotkey is: " + hb_ValToStr(RegisterHotkey(hWnd, nID3, 0, VK_F12)))
InstallEventHandler("HotkeyProc")
ACTIVATE WINDOW Win_1
ReleaseHotkey(hWnd, nID1)
ReleaseHotkey(hWnd, nID2)
ReleaseHotkey(hWnd, nID3)
Procedure HotkeyProc(hWnd, nMsg, wParam, lParam)
Local nRet := Nil , WM_HOTKEY := 786
If nMsg = WM_HOTKEY
MsgInfo("Hotkey Is Press", "Catch hotkey")
nRet := 1 // Return non Nil value
EndIf
Return nRet
- TestHotkeyHMG.zip
- (1.28 KiB) Downloaded 267 times
FreeBasic sources
#include once "windows.bi"
declare function WinMain ( byval hInstance as HINSTANCE, _
byval hPrevInstance as HINSTANCE, _
byval szCmdLine as string, _
byval iCmdShow as integer ) as integer
end WinMain( GetModuleHandle( null ), null, Command( ), SW_NORMAL )
function WndProc ( byval hWnd as HWND, _
byval wMsg as UINT, _
byval wParam as WPARAM, _
byval lParam as LPARAM ) as LRESULT
function = 0
select case( wMsg )
CASE WM_HOTKEY
MessageBox( null, "Hotkey is press", "Hotkey!!!", MB_ICONINFORMATION )
case WM_CREATE
exit function
case WM_PAINT
dim rct as RECT
dim pnt as PAINTSTRUCT
dim hDC as HDC
hDC = BeginPaint( hWnd, @pnt )
GetClientRect( hWnd, @rct )
DrawText( hDC, _
"Hello, World!", _
-1, _
@rct, _
DT_SINGLELINE or DT_CENTER or DT_VCENTER )
EndPaint( hWnd, @pnt )
exit function
case WM_KEYDOWN
if( lobyte( wParam ) = 27 ) then
PostMessage( hWnd, WM_CLOSE, 0, 0 )
end if
case WM_DESTROY
PostQuitMessage( 0 )
exit function
end select
function = DefWindowProc( hWnd, wMsg, wParam, lParam )
end function
dim wMsg as MSG
dim wcls as WNDCLASS
dim hWnd as HWND
Dim nID1 As Integer
Dim nID2 As Integer
Dim nID3 As Integer
'Dim iRet As Long
nID1 = 33000
nID2 = 33001
nID3 = 33002
function = 0
with wcls
.style = CS_HREDRAW or CS_VREDRAW
.lpfnWndProc = @WndProc
.cbClsExtra = 0
.cbWndExtra = 0
.hInstance = hInstance
.hIcon = LoadIcon( NULL, IDI_APPLICATION )
.hCursor = LoadCursor( NULL, IDC_ARROW )
.hbrBackground = GetStockObject( WHITE_BRUSH )
.lpszMenuName = NULL
.lpszClassName = @"HelloWin"
end with
if( RegisterClass( @wcls ) = FALSE ) then
MessageBox( null, "Failed to register wcls", "Error", MB_ICONERROR )
exit function
end if
hWnd = CreateWindowEx( 0, _
@"HelloWin", _
"Press F10 to F12 to the hotkey", _
WS_OVERLAPPEDWINDOW, _
CW_USEDEFAULT, _
CW_USEDEFAULT, _
CW_USEDEFAULT, _
CW_USEDEFAULT, _
NULL, _
NULL, _
hInstance, _
NULL )
'iRet = RegisterHotKey(hWnd, nID1, 0, VK_F10)
'If iRet = 0 Then
If RegisterHotKey(hWnd, nID1, 0, VK_F10) = 0 Then
MessageBox(null, "RegisterHotKey F10 fail!!", "Fail", MB_ICONERROR)
End If
'iRet = RegisterHotKey(hWnd, nID2, 0, VK_F11)
'If iRet = 0 Then
If RegisterHotKey(hWnd, nID2, 0, VK_F11) = 0 Then
MessageBox(null, "RegisterHotKey F11 fail!!", "Fail", MB_ICONERROR)
End If
'iRet = RegisterHotKey(hWnd, nID3, 0, VK_F12)
'If iRet = 0 Then
If RegisterHotKey(hWnd, nID3, 0, VK_F12) = 0 Then
MessageBox(null, "RegisterHotKey F12 fail!!", "Fail", MB_ICONERROR)
End If
ShowWindow( hWnd, iCmdShow )
UpdateWindow( hWnd )
while( GetMessage( @wMsg, NULL, 0, 0 ) <> FALSE )
TranslateMessage( @wMsg )
DispatchMessage( @wMsg )
wend
UnregisterHotKey(hWnd, nID1)
UnregisterHotKey(hWnd, nID2)
UnregisterHotKey(hWnd, nID3)
function = wMsg.wParam
end function
- TestHotkeyFB.zip
- (8.86 KiB) Downloaded 248 times
