Page 1 of 3
Problem reading Unicode file
Posted: Sat Jul 19, 2014 7:00 pm
by Clip2Mania
Anyone can suggest how to read unicode file attached?
I can open it in Windows Notepad without any problems.
I'm using HMG 3.3.1, 32 bits, Unicode.
Tried using memoread(), HB_Memoread() and FOpen(), FReadStr() combination,
both in ANSI & UNICODE versions of HMG, and apparently cannot open it.
Suggestions?
Thx,
Erik
Re: Problem reading Unicode file
Posted: Sun Jul 20, 2014 4:14 am
by bpd2000
Refer attached demo
You have to save file using Encoding UTF-8
Also refer
viewtopic.php?f=7&t=3689&p=34140&hilit= ... F+8#p34140
Posted: Sun Jul 20, 2014 6:58 am
by Clip2Mania
Yes, I saw the demo & read post previously. That is exactly the issue.
I cannot save the file in UTF-8, because it comes from an external program (EAC). I have a lot of these files and need to read them, so manually opening & saving each file is way too much work for my customer. Furthermore, I want to save him the complexity
In the mean time, found a command-line conversion tool on the web (
http://www.autohotkey.com/board/topic/9 ... icode-cmd/. which allows to do this. I use "execute file" command to convert each file first. It's not really beautiful, but it kinda works...
Posted: Tue Jul 22, 2014 1:57 am
by srvet_claudio
Clip2Mania wrote:Anyone can suggest how to read unicode file attached?
Suggestions?
Thx,
Erik
Hi Erik,
the problem is that you file is in Unicode UTF16LE (Unicode of Windows) and HMG work with UTF8,
see this code:
FUNCTION Main()
cText := HMG_UTF16LE_TO_UTF8 ("test_unicodeUTF16LE.txt")
MsgInfo (cText)
#pragma BEGINDUMP
#define UNICODE
#include "HMG_UNICODE.h"
#include <windows.h>
#include "hbapi.h"
HB_FUNC ( HMG_UTF16LE_TO_UTF8 )
TCHAR *FileName = (TCHAR *) HMG_parc (1);
HANDLE hFile;
DWORD nFileSize;
DWORD nReadByte;
hFile = CreateFile (FileName, GENERIC_READ, 0, NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
if (hFile == INVALID_HANDLE_VALUE)
return;
nFileSize = GetFileSize (hFile, NULL);
if (nFileSize == INVALID_FILE_SIZE)
{ CloseHandle (hFile);
return;
TCHAR cBuffer [ nFileSize ];
ReadFile (hFile, cBuffer, nFileSize, &nReadByte, NULL);
HMG_retc (cBuffer);
#pragma ENDDUMP
Posted: Tue Jul 22, 2014 2:37 am
Simply another approach :
Convert big-endian Unicode string to ANSI
CAUTION : Use only for big-endian Unicode string !
PROCEDURE Main
MsgBox( UniBE2UT8( HB_MEMOREAD( "test_unicode.txt" ) ) )
FUNCTION UniBE2UT8( cBigEndianStr ) // Convert big-endian Unicode string to ANSI
RETURN ( SUBSTR( STRTRAN( cBigEndianStr, CHR(0), '' ), 3 ) )
Posted: Tue Jul 22, 2014 7:57 am
by Clip2Mania
Fantastic, thanks gentlemen for the effort!
There is a problem with both codes, however
Mr. esgici's code does not read to the end of the file but stops somewhere
Dr. Claudio's code reads too much
(see the "garbage" characters at the end of the file)
Not beautiful in Msgbox, but I can filter out in my code.
Posted: Tue Jul 22, 2014 10:48 am
Clip2Mania wrote:...
There isn't such truncate problem in my method and upper extra characters in Claudio's method at my side
- UpperExtraCharactersInClaudio'sMethod
- UpperExtraCharactersInClaudio'sMethod.PNG (109.12 KiB) Viewed 26587 times
And physically there isn't such extra (letter or not) characters into your file
If you made this test on another file, please send me it.
Posted: Tue Jul 22, 2014 11:11 am
by Clip2Mania
Mr esgici,
the trouble is in the accents/special characters (it always is
I tried adding 'SET CODEPAGE TO UNICODE' at the beginning of the program, but that does not change anything.
Posted: Tue Jul 22, 2014 11:17 am
by Clip2Mania
It is true, I added the éèçàôù characters in the file, because they are very common. In the example above,
if you leave them out, you will see that they are not correctly translated further in the file.
Posted: Tue Jul 22, 2014 12:25 pm
You are right, my conversion method not convenient to your needs
