When StatusBar and Bottom ToolBar
Posted: Wed May 21, 2014 8:53 pm
When is necessary to make two ToolBars (manually, because via IDE is not possible) one Top another Bottom and you increase a StatusBar: all ToolButtons (Bottom ones) are not displayed in the right size. In order words, the ToolBar Bottom is not calculating to be displayed upper than StatusBar. So, seems Statusbar is taking place part of ToolButtons (bottom) and can not be completly displayed.
This is a fmg file example:
Please note captured screen:
- Screen.PNG (18.64 KiB) Viewed 4783 times
This problem was related from a brazilian
PCToledo forum
Re: When StatusBar and Bottom ToolBar
Posted: Thu May 22, 2014 1:48 am
by Javier Tovar
Si Pablo César,
Aquí pasa lo mismo!
Posted: Thu May 22, 2014 3:43 am
I will see how to solve this. I think Claudio can easily solve this.
Posted: Thu May 22, 2014 12:29 pm
Rathinagiri wrote:I will see how to solve this. I think Claudio can easily solve this.
I believe a new parameter with StatusBar height will be requested prior to call INITTOOLBAR at C function.
Thanks guys for your attention received.
Posted: Fri May 23, 2014 4:31 pm
by srvet_claudio
Pablo César wrote:Rathinagiri wrote:I will see how to solve this. I think Claudio can easily solve this.
I will check.
Posted: Tue May 27, 2014 8:07 pm
by srvet_claudio
srvet_claudio wrote:Pablo César wrote:Rathinagiri wrote:I will see how to solve this. I think Claudio can easily solve this.
I will check.
I fixed!
This problem is not a HMG bug, is a Windows system bug.
Posted: Tue May 27, 2014 8:59 pm
Thank you Dr. Soto !
srvet_claudio wrote:This problem is not a HMG bug, is a Windows system bug
You mean is an API bug ?
So, you must have offset this failure reading the height of the statusbar as I said, is not it ?
I just read this:
The toolbar default sizing and positioning behaviors can be turned off by setting the CCS_NORESIZE and CCS_NOPARENTALIGN common control styles. Toolbar controls that are hosted by rebar controls must set these styles because the rebar control sizes and positions the toolbar.
At
http://msdn.microsoft.com/en-us/library ... s.85).aspx
Posted: Tue May 27, 2014 9:41 pm
by srvet_claudio
Pablo César wrote:Thank you Dr. Soto !
I just read this:
At
Windows always overlaps the StatusBar and the Bottom ToolBar.
The trick is: when Windows begin to draw the Bottom ToolBar first I move it to up.
Posted: Wed May 28, 2014 12:22 am
srvet_claudio wrote:Windows always overlaps the StatusBar and the Bottom ToolBar.
Yeap
Posted: Tue Jun 03, 2014 1:50 pm
Thank you Claudio, now is working perfectly, even if you amke StatusBar after sequence of ToolButtons.
- Screen.PNG (15.46 KiB) Viewed 4549 times
PERFECTO !
