PRINT DATA With Macro Substitution
Posted: Thu May 08, 2014 3:38 am
by hmgchang
Dear Masters and Friends,
How to use the PRINT DATA with macro subtitution ( &) ?
aLabel := { "one", "two", 1000000}
aFont  := { { "Verdana", 10, "BOLD ITALIC UNDERLINE"}, ;
            { "Arial", 09, "BOLD ITALIC"}, ;
            { "Courier", 10, "BOLD"}}
FOR nLabel := 1 TO LEN( aLabel)
  nRow  := ( nLabel - 1) * 4
  nCol  := 5 + 4
  cBIU := aFont[ nLabel, 3]
  @ nRow, nCol PRINT T_AllToChar( aLabel[ nLabel]) ;
    FONT aFont[ nLabel, 1] ;
    SIZE aFont[ nLabel, 2]
    &cBIU
    // CENTER
Get an compile error !
TIA
Best Rgds,
Chang
Re: PRINT DATA With Macro Substitution
Posted: Thu May 08, 2014 4:17 am
    SIZE aFont[ nLabel, 2] ;
    &cBIU
Did you miss the ; in the third line?
Tried in a single line?
Posted: Thu May 08, 2014 5:29 am
by mol
hmgchang wrote:Dear Masters and Friends,
  nCol  := 5 + 4
    &cBIU
    // CENTER
TIA
Best Rgds,
Chang
Only way, I found to use variables to define bold, italic, underline was to convert @ nRow, nCol PRINT phrase to function:
_HMG_PRINTER_H_PRINT ( _HMG_SYSDATA[374], nStartRow, nStartCol ,;
			cFontName, nFontSize,;
			nColorR, nColorG, nColorB ,;
			cTextToPrint ,;
			lBold, lItalic, lUnderline, lOverline ,;
			.T. ,;
			.T. ,;
			.T. ,;
			cJust )
for multilines printout:
_HMG_PRINTER_H_MULTILINE_PRINT ( _HMG_SYSDATA[374], nStartRow, nStartCol ,;
			nEndRow, nEndCol,;
			cTextToPrint ,;
			.T. ,;
			.T. ,;
			.T. ,;
			cJust )
Posted: Fri May 09, 2014 7:58 am
by hmgchang
Yes Mr. Diamond, I missed the colon... thks
Good suggestion Mr. Marek Olszewski and thks, I will give a try...
but should i include any file or libs ?
Posted: Fri May 09, 2014 12:01 pm
by mol
Any include is required
Posted: Sat May 10, 2014 4:20 am
by hmgchang
Salute for Mr. Mol...
It is working now... thks a lot...
BTW, any idea what the 3 boolean( .T.) after the lOverLine ?
Posted: Sat May 10, 2014 5:35 am
hmgchang wrote:BTW, any idea what the 3 boolean( .T.) after the lOverLine ?
It's about of: <.lcolor.>,<.lfont.>,<.lsize.>
According C:\HMG.3.2\INCLUDE\i_print.ch:
_HMG_PRINTER_H_MULTILINE_PRINT ( _HMG_SYSDATA \[ 374 \] , ;
                                 <Row> , ;
                                 <Col> , ;
                                 <ToRow> , ;
                                 <ToCol> , ;
                                 <cFontName> , ;
                                 <nFontSize> , ;
                                 <aColor>\[1\] , ;
                                 <aColor>\[2\] , ;
                                 <aColor>\[3\] , ;
                                 <cText> , ;
                                 <.bold.> , ;
                                 <.italic.> , ;
                                 <.underline.> , ;
                                 <.strikeout.> , ;
                                 <.lcolor.> , ;
                                 <.lfont.> , ;
                                 <.lsize.> , ;
                                 <"align"> )
Posted: Mon May 12, 2014 6:40 am
by hmgchang
Thanks very much mr. Cesar.
When the command print preview, it display toolbar for Save
instead of printing... but it only save to .emf ?
How about to other format or PDF ?
Pls help me...
Thks n Rgds
Chang
Posted: Mon May 12, 2014 12:35 pm
hmgchang wrote:When the command print preview, it display toolbar for Save
ToolBars in HMG_PREVIEW it for your own options. User decides if wants to print or just PREVIEW.
In the next HMG release, we can count with others options to convert metafiles to other image format like: "BMP","JPG","GIF","TIFF","PNG".
For this option, we can count with HMGHPDF it is so simple and very good library. See also an example at C:\HMG.3.2\hfcl\Samples\HMGHPDF\demo.Prg
Pls help me...
Helping in what ? Many question: many responses... you need to study deep into HMG sources. All it is in your own computer when HMG is installed. I suggest to see all HMG examples in SAMPLES folder and you will learn a lot with it.
Posted: Tue May 13, 2014 5:38 am
by hmgchang
:D Thks Sirs,
Really the HMGHPDF is wonderful...
only the supported fonts limited .
Best Rgds
Chang
