Page 1 of 2
Ayuda con grafica
Posted: Thu Oct 24, 2013 12:54 am
by martingz
Estoy tratando de generar una grafica usando un grid para lograr lo que me piden, hay alguna manera de hacer que las lineas del frid, reduzcan su ancho para lograr que ajustar a la ventana, es decir sin usar los scrolls
- grafica.jpg (66.41 KiB) Viewed 3946 times
Re: Ayuda con grafica
Posted: Thu Oct 24, 2013 8:59 am
martingz wrote:Estoy tratando de generar una grafica usando un grid para lograr lo que me piden, hay alguna manera de hacer que las lineas del frid, reduzcan su ancho para lograr que ajustar a la ventana, es decir sin usar los scrolls
Google translate wrote:I'm trying to generate a graph using a grid to achieve what you ask, is there any way to make the grid lines, reduce its width to get fit to window, ie without using scrolls
Hola Martin
Does we can see your (SSW) code ?
Viva HMG
Ayuda con grafica
Posted: Thu Oct 24, 2013 11:16 am
Hola Martin,
En mi opinion, para que no precises utilizar el scrollbar vertical, deberias utilizar otra escala para que quepa en la ventana.
Posted: Thu Oct 24, 2013 12:34 pm
In my opinion, to precises not use the vertical scrollbar, you should use a different scale to fit the window.
Good opinion
and another point : why GRID
Happy HMG'ing
Posted: Thu Oct 24, 2013 1:29 pm
by martingz
Esgici , Pablo thanks for answering.
is a time chart, so the most accurate way to show it on in 4 lines per hour , in periods of 15 minutes
Esgici,It is on a grid that I need to form in the same line up to three entries per day, and the grid was adjusted to my needs, only now the user wants to see everything in the window without the scrolls
Posted: Thu Oct 24, 2013 3:35 pm
martingz wrote:...It is on a grid that I need to form in the same line up to three entries per day, and the grid was adjusted to my needs, only now the user wants to see everything in the window without the scrolls
OK, well...
Where from will come images ?
There isn't any probability to change base values at run-time ?
Posted: Thu Oct 24, 2013 5:12 pm
by martingz
There are not pictures, coloring the cells of the grid individually
Try to find a chart, but none meets the requiements of the end user, the only thing stopping me is that I can not change the width of the rows of the grid.
I'm trying right now with RMChart
Posted: Thu Oct 24, 2013 5:38 pm
martingz wrote:There are not pictures, coloring the cells of the grid individually...
Good idea
May be a character string colored with length on base value in a single cell ? ( as a horizontal bar for each line in the left GRID )
FE: REPLICATE( CHR( 255 ), <nBaseValue> / <nIncrement> )
Anyway, the opinion of Pablo is good and applicable, I think.
Because in graphics, the goal is to demonstrate numeric values as picture / shape for build a visual comparison; neat accuracy may not be very important in many cases.
Happy HMG'ing
Posted: Thu Oct 24, 2013 7:48 pm
by martingz
Unfortunately the end user wants with 4 lines per hour, so that visually it easier
I think Pablo is right
Was my first elecion, 2 lines per hour, but did not accept
Good idea , gave me a good point, try to make it with two different characters one at half and full otherwise, so will use nothing but 2 lines per hour
Thank you very much
Posted: Thu Oct 24, 2013 7:59 pm
"End user" ...
Yes, our
spoiled user ...
I wish easiness to you ...
If we have anything to make for you, please don't hesitate to ask
Happy HMG'ing
