Page 1 of 3
ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 2:07 am
by andyglezl
Hola a todos
Como puedo saber cuando se mueve de lugar una ventana ?
Probé con "ON MOUSEDRAG" pero no ejecuta mi funcion. Algun ejemplo ?
Hello everyone
As I can know when moving from place a window?
I tried "ON MOUSEDRAG" but does not execute my function. Some example?
ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 11:51 am
Hola Andrés,
Fijate si este ejemplo te ayuda a resolver. Try this:
MoveWindow2.rar
(825.17 KiB) Downloaded 781 times
Message re-edited to attached mouse pointers files and for second time to include source code file (was missing, sorry).
ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 12:05 pm
Disculpame. La solucion que presenté, creo que no resuelve tu caso.
Sorry. This example which I had presented, will not solve your case.
Re: ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 2:28 pm
andyglezl wrote: As I can know when moving from place a window?
I'm not sure that I have understood correct :?
I hope attached sample will help you :arrow:
Screenshoot of Moving Window sample
MoveWindow.zip
Source ( .prg, fmg, hbp, .bmp ) files of Moving Window sample
(5.94 KiB) Downloaded 473 times
Re: ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 2:34 pm
by bpd2000
Thank you, Esgici for sharing
Re: ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 2:59 pm
by srvet_claudio
andyglezl wrote:Hola a todos
Hello everyone
See this code:
		WIDTH 640 ;
		HEIGHT 480 ;
		TITLE 'Move Window' ;
      @  100 , 10 LABEL Label_X VALUE "" AUTOSIZE
      @  150 , 10 LABEL Label_Y VALUE "" AUTOSIZE
   CENTER WINDOW Form_1
   #define WM_MOVE 3
   CREATE EVENT PROCNAME MoveTest() HWND Form_1.HANDLE MSG WM_MOVE
FUNCTION MoveTest()
LOCAL xPos := LOWORD(EventlParam())
LOCAL yPos := HIWORD(EventlParam())
   Form_1.Label_X.Value := "X = " + HB_NTOS(xPos)
   Form_1.Label_Y.Value := "Y = " + HB_NTOS(yPos)
Re: ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 4:02 pm
srvet_claudio wrote: ...
See this code:
Apparently, we need ON MOVE event ;)
Viva HMG :D
ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 4:19 pm
srvet_claudio wrote:See this code:
#define WM_MOVE 3
FUNCTION MoveTest()
Very Good Doctor !!
So the code I posted could be improved like this:
#define HTCAPTION          2
#define WM_MOVE            3
#define WM_NCLBUTTONDOWN   161
	WIDTH 400 ;
	HEIGHT 200 ;
	TITLE 'Hello World!' ;
	MAIN ;
	ON MOUSECLICK MoveActiveWindow()
	DEFINE STATUSBAR
        STATUSITEM "Click on Form and holding mouse's button for moving this window"
    END STATUSBAR
	DEFINE LABEL Label_1
		ROW	100
		COL	10
		VALUE ""
	END LABEL
// Form_1.Cursor := "hand32-32.cur"
Form_1.Cursor := "Move-32.cur"
Function MoveActiveWindow( hWnd )
DEFAULT hWnd := GetActiveWindow()
PostMessage( hWnd, WM_NCLBUTTONDOWN, HTCAPTION, 0 )
// FileCursor( "Grabbed32-32.cur" )
FileCursor( "Maggy.ani" )
Function MoveTest()
Local xPos := LOWORD(EventlParam())
Local yPos := HIWORD(EventlParam())
Form_1.Label_1.Value:="Lin: "+Str(yPos,3,0)+" / Col: "+Str(xPos,3,0)
#pragma BEGINDUMP
#include <windows.h>
HB_FUNC( FILECURSOR )
   hb_retnl( ( LONG ) SetCursor( LoadCursorFromFile( hb_parc( 1 ) ) ) );
#pragma ENDDUMP
Nice example for move events. Thanks again Claudio !
ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 8:12 pm
Hereunder is some cursor pointers, one is animated cursor pointer. :)
New_Mouse_pointers.rar
(2.7 KiB) Downloaded 575 times
I hope you enjoy ! (Sorry I couldn't resist it...)
Re: ON MOUSEDRAG ?
Posted: Tue Sep 10, 2013 9:28 pm
by andyglezl
Gracias Pablo César, esgici y Claudio
Revisé los ejemplos que enviaron e hice esto.
La idea que traigo es crear 2 ventanas, y que al mover la ventana 'Main',
la ventana 'Child' se acople a un lado de la 'Main'.
El siguiente código ya lo hace, hay que mover la ventana MAIN y darle click,
la ventana CHILD se ubicara a un lado de la MAIN. Lo que quiero es que
automaticamente la ventana CHILD se "acople" al deja de pulsar el botón del
ratón.
Thanks Pablo Cesar, Esgici and Claudio
I checked the examples sent and made this.
The idea is to create 2 windows bring, and that moving the window 'Main'
window 'Child' engages a side of the 'Main'.
The following code already does, you have to move the MAIN window and give click,
CHILD window was located on one side of the MAIN. What I want is that
CHILD window is automatically "attach" to stop pressing the button
mouse.
#define HTCAPTION          2
#define WM_MOVE            3
    DEFINE WINDOW Form_1 AT 0,0 WIDTH 400 HEIGHT 600 TITLE 'Hello World!' MAIN ;
		   ON MOUSECLICK MoveActiveWindow() ;
		   ON INIT (  CreaChild( GetFormHandle('Form_1') ), MoveActiveWindow( hWnd )  )
		DEFINE STATUSBAR
		END STATUSBAR
FUNCTION CreaChild()
	Local xPos := Form_1.Row
	Local yPos := Form_1.Col
	Local nWidth := Form_1.Width
	DEFINE WINDOW Form_2 AT xPos,yPos+nWidth WIDTH 300 HEIGHT 200 TITLE 'WinChild' CHILD
		DEFINE STATUSBAR
                STATUSITEM "This window CHILD will be 'anchored' to the MAIN ..."
		END STATUSBAR
    ACTIVATE WINDOW Form_2
RETURN Nil
	Form_1.StatusBar.Item(1):="Lin: "+Str(yPos,3,0)+" / Col: "+Str(xPos,3,0)
	Form_2.Row:=xPos
	Form_2.Col:=yPos+nWidth
