Help: How can I detect system power shutdown, logoff, etc.
Posted: Mon Nov 08, 2010 9:18 am
by dhaine_adp
Hello all,
Has anyone got a code to detect logoff, shutdown, restart, hibernate, sleep and suspend in windows?
If I have an application that logs the time or duration (start time and end time) and if windows suddenly restarted, logoff by user without closing the application. So at least if the shutdown, logoff event is detected I can update the "End Time and End Date" and then close the app. I believed I cannot prevent the shutdown and I don't to intefere with it. What I wanted is simply update and closed the Apps.
Is this possible with HMG? Any help and advise is welcome..
Danny
Re: Help: How can I detect system power shutdown, logoff, et
Posted: Mon Nov 08, 2010 10:06 am
by gfilatov
dhaine_adp wrote:Hello all,
Hello Danny,
Yes, it is possible with HMG. You should trap the Windows messages WM_QUERYENDSESSION and WM_ENDSESSION in your local function Events(). Please be so kind to revise a working skeleton of program for Minigui Extended and try to adapt this code for HMG.
#include "minigui.ch"
#define APP_TITLE "Hello World!"
	SET EVENTS FUNCTION TO MYEVENTS
	DEFINE WINDOW Win_1 ;
		WIDTH 400 ;
		HEIGHT 400 ;
		TITLE APP_TITLE ;
	CENTER WINDOW Win_1
	ACTIVATE WINDOW Win_1
#define WM_QUERYENDSESSION              0x0011
#define WM_ENDSESSION                   0x0016
function MyEvents ( hWnd, nMsg, wParam, lParam )
	do case
	case nMsg == WM_QUERYENDSESSION
               MSGINFO("OK", "QUERY")
               Return 1  // try 0 to block the exit
	case nMsg == WM_ENDSESSION
               MSGINFO("OK", "END")
               Return 1
	otherwise
	endcase
Return (0)
Hope that give you an idea :idea:
Posted: Wed Nov 10, 2010 4:50 am
by dhaine_adp
Hi Grigory,
Thank you very much for posting. I will try your code.
Danny
