Hello all,
Has anyone got a code to detect logoff, shutdown, restart, hibernate, sleep and suspend in windows?
If I have an application that logs the time or duration (start time and end time) and if windows suddenly restarted, logoff by user without closing the application. So at least if the shutdown, logoff event is detected I can update the "End Time and End Date" and then close the app. I believed I cannot prevent the shutdown and I don't to intefere with it. What I wanted is simply update and closed the Apps.
Is this possible with HMG? Any help and advise is welcome..
Danny
Help: How can I detect system power shutdown, logoff, etc.
- dhaine_adp
Danny
Manila, Philippines
Danny
Manila, Philippines
Re: Help: How can I detect system power shutdown, logoff, et
Hello Danny,dhaine_adp wrote:Hello all,
Yes, it is possible with HMG. You should trap the Windows messages WM_QUERYENDSESSION and WM_ENDSESSION in your local function Events(). Please be so kind to revise a working skeleton of program for Minigui Extended and try to adapt this code for HMG.
#include "minigui.ch"
#define APP_TITLE "Hello World!"
SET EVENTS FUNCTION TO MYEVENTS
DEFINE WINDOW Win_1 ;
WIDTH 400 ;
HEIGHT 400 ;
TITLE APP_TITLE ;
MAIN
CENTER WINDOW Win_1
ACTIVATE WINDOW Win_1
#define WM_QUERYENDSESSION 0x0011
#define WM_ENDSESSION 0x0016
function MyEvents ( hWnd, nMsg, wParam, lParam )
do case
case nMsg == WM_QUERYENDSESSION
MSGINFO("OK", "QUERY")
Return 1 // try 0 to block the exit
case nMsg == WM_ENDSESSION
MSGINFO("OK", "END")
Return 1
otherwise
endcase
Return (0)
- dhaine_adp
Hi Grigory,
Thank you very much for posting. I will try your code.
Danny
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
