Page 1 of 2
Harbour Gdi library
Posted: Mon Aug 16, 2010 4:47 pm
by l3whmg
Hi friends,
Is there someone that use Gdi (libhbgd.a) with Harbour?
During compilation I receive more errors that sounds like this :
".../lib/libhbgd.a(gdwrp.o):gdwrp.c:(.text+0x5f9c): undenifed reference to 'gdImageGdptr@8'
I've included "gd.ch", "gdextern.ch" and "libhbgd.a"; I've donwloaded binary packages for MsWin from
http://www.libgd.org, but there isn't library for MinGw (only .lib).
Any help is good!
Many thanks in advance.
Re: Harbour Gdi library
Posted: Mon Aug 16, 2010 8:21 pm
by Ricci
Luigi, what you want to do with the GDi lib?
The FreeImage lib won´t do it? Because this one is working with HMG.
Ciao ... Ricci
Posted: Wed Aug 18, 2010 8:10 am
by l3whmg
Hi Ricci,
many thanks for your fast replay
I want try to create/print barcode and I have read about functions inside Gdi. But now, with your replay, I read about Freeimage
Ciao and best regards.
P.S. You are in Italy?
Posted: Wed Aug 18, 2010 11:45 am
Ciao Luigi
l3whmg wrote:
I want try to create/print barcode and ...
Our friend Mustafa had made good works on barcode:
viewtopic.php?f=19&t=1179&p=11534
I hope that help you
Regards.
Posted: Wed Aug 18, 2010 12:14 pm
by l3whmg
Hi Esgici, My Friend
Many thanks for this information: I'll read!
Many times ago, I've developped a solution for Barcode 39 and 128, but it was mandatory to have fonts installed.
I think it was not a great solution because:
a) normally, you must pay for good font
b) you must install it (I think about a lan). For these reasons I'm searching a better solution.
Well, many thanks and now I'll look to the material!
Posted: Wed Aug 18, 2010 6:06 pm
by Ricci
l3whmg wrote:Hi Ricci,
Luigi, no i´m neither in Italy nor am i italian. Only my name.
Ciao from Berlin ... Ricci
Posted: Thu Aug 19, 2010 5:47 pm
by l3whmg
Hi Ricci,
I'm very pleasure to meet you from the north of the Italy
I'm investigating inside freeimage (I'm a selfmade and newbe
). The first problem (solved) was to give one library in MinGw style (.a).
Now I'm trying my experiments: the first is good (saved a very simple bitmap and get info about this). The second (from Internet) not work: give me error "bad argument". I don't know.
Where can I find example(s)/source(s) write with Harbour/Clipper ?
Hallo und bis bald
P.S. I hope Google translator is good!! I want say to You: Ciao e a presto.
Posted: Thu Aug 19, 2010 8:44 pm
by Ricci
Hi Luigi,
yes Goole translater is good.
There is one big problem with the freeimage-lib: Harbours libhbfimage.a doesn´t support all freeimage functions.
Grüße aus Berlin ... Ricci
Posted: Wed Aug 25, 2010 12:13 pm
by l3whmg
Hi Ricci,
I'm sorry for delay but I was out for holidays with family
Many thanks for your replay: now I investigate.
Best regards
Posted: Thu Aug 26, 2010 1:02 am
Hola l3whmg:
hay varios sitios gratis descarga de fuentes de barras
ej:
http://www.barcodesinc.com/free-barcode-font/
otro:
http://www.idautomation.com/fonts/free/
mejor:
http://www.squaregear.net/fonts/free3of9.shtml
trabajar con imagenes es dificil y engorrosos
un abrazo
si necesitas una mano avisa
Translate Google
Hello l3whmg:
there are several free sites bar font download
work with images is difficult and cumbersome
a hug: D
if you need a hand alerts
