Harbour Gdi library
Harbour, MingW related news.
l3whmg
Harbour Gdi library
Post by l3whmg »
Hi friends,
Is there someone that use Gdi (libhbgd.a) with Harbour?
During compilation I receive more errors that sounds like this :
".../lib/libhbgd.a(gdwrp.o):gdwrp.c:(.text+0x5f9c): undenifed reference to 'gdImageGdptr@8'
I've included "gd.ch", "gdextern.ch" and "libhbgd.a"; I've donwloaded binary packages for MsWin from http://www.libgd.org, but there isn't library for MinGw (only .lib).
Any help is good!
Many thanks in advance.
Luigi from Italy
www.L3W.it
Ricci
Re: Harbour Gdi library
Post by Ricci »
Luigi, what you want to do with the GDi lib?
The FreeImage lib won´t do it? Because this one is working with HMG.
Ciao ... Ricci
l3whmg
Post by l3whmg »
Hi Ricci,
many thanks for your fast replay ;)
I want try to create/print barcode and I have read about functions inside Gdi. But now, with your replay, I read about Freeimage :!:
Ciao and best regards.
P.S. You are in Italy?
Luigi from Italy
www.L3W.it
Ciao Luigi
l3whmg wrote: I want try to create/print barcode and ...
Our friend Mustafa had made good works on barcode:
viewtopic.php?f=19&t=1179&p=11534
I hope that help you :)
Regards.
l3whmg
Post by l3whmg »
Hi Esgici, My Friend :D
Many thanks for this information: I'll read!
Many times ago, I've developped a solution for Barcode 39 and 128, but it was mandatory to have fonts installed.
I think it was not a great solution because: a) normally, you must pay for good font b) you must install it (I think about a lan). For these reasons I'm searching a better solution.
Well, many thanks and now I'll look to the material!
Luigi from Italy
www.L3W.it
Ricci
Post by Ricci »
l3whmg wrote:Hi Ricci,
Luigi, no i´m neither in Italy nor am i italian. Only my name.
Ciao from Berlin ... Ricci
l3whmg
Post by l3whmg »
Hi Ricci,
I'm very pleasure to meet you from the north of the Italy :!:
I'm investigating inside freeimage (I'm a selfmade and newbe :oops: ). The first problem (solved) was to give one library in MinGw style (.a).
Now I'm trying my experiments: the first is good (saved a very simple bitmap and get info about this). The second (from Internet) not work: give me error "bad argument". I don't know.
Where can I find example(s)/source(s) write with Harbour/Clipper ?
Hallo und bis bald
P.S. I hope Google translator is good!! I want say to You: Ciao e a presto.
Luigi from Italy
www.L3W.it
Ricci
Post by Ricci »
Hi Luigi,
yes Goole translater is good. :D
There is one big problem with the freeimage-lib: Harbours libhbfimage.a doesn´t support all freeimage functions.
Grüße aus Berlin ... Ricci
l3whmg
Post by l3whmg »
Hi Ricci,
I'm sorry for delay but I was out for holidays with family :)
Many thanks for your replay: now I investigate.
Best regards
Luigi from Italy
www.L3W.it
Hola l3whmg:
hay varios sitios gratis descarga de fuentes de barras
ej: http://www.barcodesinc.com/free-barcode-font/
otro: http://www.idautomation.com/fonts/free/
mejor: http://www.squaregear.net/fonts/free3of9.shtml
trabajar con imagenes es dificil y engorrosos
un abrazo :D
si necesitas una mano avisa
Translate Google
Hello l3whmg:
there are several free sites bar font download
work with images is difficult and cumbersome
a hug: D
if you need a hand alerts
