ListBox Multiselect value - Read only?
Posted: Tue May 25, 2010 3:38 pm
Multiselect enabled ListBox can not be initialized or set to user defined value. Is that only a read-only property?
Consider this small sample.
* HMG Hello World Demo
* (c) 2002-2004 Roberto Lopez <mail.box.hmg@gmail.com>
DEFINE WINDOW Win1 ;
WIDTH 400 ;
HEIGHT 400 ;
TITLE 'Hello World!' ;
DEFINE LISTBOX LIST1
ROW 10
COL 10
WIDTH 100
HEIGHT 110
ITEMS { '01','02','03','04','05','06','07','08','09','10' }
multiselect .t.
END LISTBOX
define button click
row 10
col 120
width 50
caption "Click"
action Win1.LIST1.value := {1,2}
end button
ACTIVATE WINDOW Win1
I want to show the listbox with the first and second item, selected.
Re: ListBox Multiselect value - Read only?
Posted: Tue May 25, 2010 5:04 pm
by Roberto Lopez
rathinagiri wrote:Multiselect enabled ListBox can not be initialized or set to user defined value. Is that only a read-only property?
WIDTH 400 ;
HEIGHT 400 ;
ROW 10
COL 10
WIDTH 100
HEIGHT 110
multiselect .t.
END LISTBOX
define button click
row 10
col 120
width 50
caption "Click"
end button
I'll check it.
Thanks for reporting.
Posted: Tue May 25, 2010 6:18 pm
by gfilatov
Hi Roberto,
Please be so kind to update the following C-function in the file c_listbox.c:
HB_FUNC( LISTBOXSETMULTISEL )
PHB_ITEM wArray;
HWND hwnd = ( HWND ) hb_parnl( 1 );
int i;
int n;
int l;
wArray = hb_param( 2, HB_IT_ARRAY );
l = hb_parinfa( 2, 0 ) - 1;
n = SendMessage( hwnd, LB_GETCOUNT, 0, 0 );
// CLEAR CURRENT SELECTIONS
for( i = 0; i < n; i++ )
SendMessage( hwnd, LB_SETSEL, (WPARAM) (0), (LPARAM) i );
// SET NEW SELECTIONS
for( i = 0; i <= l; i++ )
SendMessage( hwnd, LB_SETSEL, (WPARAM) (1), (LPARAM) (hb_arrayGetNI(wArray, i + 1)) - 1 );
Hope that helps
Posted: Tue May 25, 2010 10:51 pm
by Roberto Lopez
gfilatov wrote:Hi Roberto,
Thanks Grigory!!!
I've come here to inform Rathi that I'm sure that is a Harbour compatibility problem related with internal changes introduced in 2.0.
You saved me a lot of researching time...
Thanks again!!!
Posted: Tue May 25, 2010 10:56 pm
by Roberto Lopez
Attached is a fixed libhmg.a.
Posted: Tue May 25, 2010 11:29 pm
Thanks Roberto
Best regards
Posted: Wed May 26, 2010 1:18 am
Thanks a lot Roberto for this quick fix.
Posted: Wed May 26, 2010 12:57 pm
by gfilatov
Roberto Lopez wrote:
Thanks Grigory!!!
Thanks again!!!
Hello Roberto,
I'm glad to help
Your time is very important for HMG community
Posted: Thu May 27, 2010 12:48 am
by Roberto Lopez
gfilatov wrote:Roberto Lopez wrote:
Thanks Grigory!!!
Thanks again!!!
Hello Roberto,
I'm glad to help
Sadly I'll must spent some time now, trying to understand the true meaning of your answer
